One Plus 6T fingerprint sensor greyed out issue
  1. vivekvejandla
    Donut Feb 23, 2019
    vivekvejandla , Feb 23, 2019 :
    Hi I have purchased the 6T in November and after one month I started facing an issue with fingerprint sensor being greyed out ,so we won't be able to unlock it and need a pin to unlock the device .Is anyone facing the same issue ? Please help me out .Thanks.
    zaminul likes this.
  2. Cunkrinks
    Froyo Feb 23, 2019
    Cunkrinks , Feb 23, 2019 :
    Was the fingerprint still greyed out next unlock after you enter the pin?
    If it not and that was security reason, for some period of time you need to enter the pin to unlock.
  3. vivekvejandla
    Donut Feb 23, 2019
    Yeah after entering the pin ,the next fingerprint unlock works fine.The security reason might be a reason but was little trouble at times of need.
  4. Cunkrinks
    Froyo Feb 23, 2019
    well that's life mate, more secure and then less comfortable.
    let's go back when there was no security on the phone, just press your power button and you can use your phone.
  5. vivekvejandla
    Donut Feb 23, 2019
    If it's a security reason all well bro but just posted to ensure that's not a bug in my device.
    PsychPineappleDude likes this.
  6. Cunkrinks
    Froyo Feb 23, 2019
    yup i got the point, now you know it's not a bug or defect.
    vivekvejandla likes this.
  7. G1550908039034
    Cupcake Feb 23, 2019
    G1550908039034 , Feb 23, 2019 :
    I have the same issue with the fingerprint sensor. I couldn't get past it after only a couple of days, and decided to just use the face unlock feature.
  8. Cunkrinks
    Froyo Feb 23, 2019
    i don't think you have the same issue, what i got from your post is your fingerprint still work (scanning) but cannot get you fingerprint, if it's like that try to remove and re enter your fingerprint, and you can follow pinned thread about screen lock how to.
    if it is the same issue, i think the security still apply whether you use fingerprint or face unlock.
  9. Atanu Maji
    Honeycomb May 18, 2019
    Atanu Maji , May 18, 2019 :
    From India, A new OnePlus user.
    Device: OnePlus 6T.
    Fingerprint scanner was slow since the day I started using the phone. So, I read in this forum to calibrate the fingerprint scanner by dialling *#808# and I did. Since then it stopped recognising my fingerprints completely while unlocking the device.
    To sort out the problem/issue,
    1. I deleted all of the registered imprints and re-registered but result were the same, “Not recognised”, “Too many attempts. Fingerprint scanner disabled.” I posted bug report from developer setting under the guidance of OP developer ‘bug Hunter’
    2. As it was under 10 days replacement I called Amazon Customer Care Representative and they suggested a ‘Hard Reset’.
    3. I back-up data and did a soft reset from settings. Duriy and after Android set-up I re-registered fingerprints but while unlocking it didn't work. Then did a Hard Reset from the Recovery. Didn't Work. Downloaded Latest Stable and Open Beta. Reflashed Stable, reattempted with the fp scanner and then flashed Beta, didn't work.
    4. Called OnePlus Customer Care and they suggested me to visit Service Center which 220 km away. Hence Pickup option they referred.
    5. I registered by giving one and another attempts with different finger's imprints, even after registering the brothers finger imprints separately, it failed to recognize.
    6. Then I had to ask for a replacement to Amazon which was a complicated process.
    Summary: Fingerprints are registering, that means Hardware Sensor is okay. It's not recognizing at the time of unlocking the phone but then if there's problem with software OOS, I clean flashed both the firmwares from OnePlus official website. I don't know the actual reason.
  10. Atanu Maji
  11. H1558151300063
    Cupcake May 18, 2019
  12. Tarang_ch97
    Cupcake Jun 6, 2019
  13. E1560619755798
    Donut Jun 20, 2019
    E1560619755798 , Jun 20, 2019 :
  14. zaminul
    Cupcake Nov 21, 2019
  15. zaminul
  16. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Nov 21, 2019
    Artemus , Nov 21, 2019 :
    Is it the same error the OP had?
  17. bojantomic
    Honeycomb Nov 21, 2019
    Artemus likes this.
  18. Henrycruise
    Cupcake Dec 22, 2020
    Henrycruise , Dec 22, 2020 :
    To ON your Ambient Display
    1. Move to the Setting on your phone
    2. Go to the Ambient display settings
    3. Turn on both ‘Pick up your phone to show’ and ‘Tap your screen to show’ options.
    4. It will activate your Ambient display for better access.
    To Remove Your Previous Fingerprints
    1. Head to the Settings and open its menu.
    2. Tap on to the Security & lock-screen.
    3. Touch the Fingerprint option and it will ask you to confirm your password or PIN or Pattern, you had set earlier to unlock your phone.
    4. After confirming the details you will see the trash icon next to each finger you have printed before. Click on this icon and confirm the remove Finger option.
    Thanks & Regards
    CDSCO Registration
