14
one plus 7 ambient display problem on 10.3.3
  1. G_kartik_kanwar_ckph
    Donut Jun 3, 2020
    G_kartik_kanwar_ckph , Jun 3, 2020 :
    so yesterday i updated my oneplus 7 to 10.3.3 and ambient display or i can say single tap to wake is not working, if and if only i keep my phone to rest for a while like 30secs or so but if i lock the phone and instantly tap back again the ambient display turns up its a huge buy on 10.3.3 now what to do and who else is having the same problem?
  2. Liehjan
    Lollipop Jun 3, 2020
    Liehjan , Jun 3, 2020 :
    Have you tried to clear cache from ambient display app?
  3. G_kartik_kanwar_ckph
    Donut Jun 3, 2020
    where to do that nd bro i dont think it will help.... it's a software glitch
    Anmol_46 likes this.
  4. Anmol_46
    Froyo Jun 3, 2020
  5. Liehjan
    you either try it or don't... Every time you don't try something you 100% miss the opportunity to maybe get the issue fixed.
    settings - apps - ambient display - clear cache
  6. Anmol_46
    Froyo Jun 3, 2020
    Anmol_46 , via OnePlus 7 , Jun 3, 2020 :
    I tried doing that but issue is still there.
    Raan Saurav and paritosh9199 like this.
  7. m3rs3d
    Cupcake Jun 3, 2020
    m3rs3d , Jun 3, 2020 :
    Same here. Not working since update.
    H1570196076554 and Raan Saurav like this.
  8. Liehjan
    Worth a shot... Then only solution is to wait for a software fix
    Raan Saurav likes this.
  9. G_kartik_kanwar_ckph
    Donut Jun 3, 2020
    but these kind of basic things should always work in a phone now we don't know till when we have to use the phone like this hopes this get's fix in day or two
  10. Anmol_46
    Froyo Jun 3, 2020
    Rightly said my brother. They provide stable updates every 2 months and that to with major bugs in it at least not expecting this from Oneplus. This is a major issue which they need to fix asap.
  11. Artemus.
    Nougat Jun 3, 2020
    Artemus. , Jun 3, 2020 :
    Do you have the option enabled?
  12. G_kartik_kanwar_ckph
    Donut Jun 4, 2020
    G_kartik_kanwar_ckph , Jun 4, 2020 :
    yes bro it is enabled it some time works some time not nd is it working for you if you have OP7?
  13. iamraj21
    Cupcake Jun 4, 2020
  14. prasad321
    Gingerbread Jun 5, 2020
    prasad321 , via OnePlus 7 , Jun 5, 2020 :
    i am facing the same problem. let me explain how to reproduce.
    i am on stable build 10.3.3 on my OnePlus 7
    1. enable tap to wake in ambient display or double tap to wake up the screen in setting->button and gestures.(both can not be enabled at same time as of now)
    2. it will work if you instantly check after enabling it. but if you lock the screen and place the phone untouched for more than 10-15 min and then try to tap or double tap it will not work.
    my thought is, its killing the background process of double tap or single tap while increasing the battery backup.
    I have raised the bug for the same lets see when it will get resolved.
    Thanks,
    Prasad
  15. G_kartik_kanwar_ckph
    Donut Jun 5, 2020
    G_kartik_kanwar_ckph , Jun 5, 2020 :
    but i don't know why oneplus gave SW to increase battery life because battery life was good atleast on my OP7 i always use dark mode but that ambient display should be fixed soon...
  16. prasad321
    battery performance improvement is needed as device gets older it will be going to degrade. they will fix this issue but should not go till next security patch.
  17. Subhendu kanjilal
    Donut Jun 5, 2020
    Subhendu kanjilal , Jun 5, 2020 :
    I am facing this issue ambient display tap to show pick-up to show is not working my phone please fix an update
    phone uses very difficult
    please help
  18. Priyansh_kimtee
    Cupcake Jun 5, 2020
  19. m3rs3d
    Cupcake Jun 8, 2020
    m3rs3d , Jun 8, 2020 :
    Yes it's enabled. It works just for a couple of minutes and after about 5-10min standing it doesn't. OP 7 version 10.3.3
  20. #20
