one plus 7 pro auto rotate.
  1. crancour
    Donut Aug 7, 2019
    crancour , Aug 7, 2019 :
    Hi. My auto rotate keeps turning it self off. Does anyone know how I can fix it? Thankyou.
  2. Albert_Stockinger
    Eclair Aug 8, 2019
    Albert_Stockinger , Aug 8, 2019 :
    Hi!
    I'm guessing it's the "Battery Saver".
    Question - are you using this feature? ... if yes, then read on ->
    Effect - whenever the "Battery Saver" is (re)activated, it turns off e.g. "screen rotation". Also the "Display-Sleep-Time" is always set down to 30 Seconds.
    It is now stupid if the "Battery Saver" is active and you recharge your mobile phone. In this case it is switched off and switched on again after charging. -> The "Battery Saver"-Settings will be restored unasked.
    I would wish that the "Battery Saver" is no longer switched on & off when charging the phone ... that would be a viable solution for me.
    Wolf4 and P1561468923357 like this.
  3. crancour
    Donut Aug 8, 2019
  4. Wolf4
    Cupcake Aug 17, 2019
  5. Mohit_14
    Donut Aug 29, 2019
    Mohit_14 , Aug 29, 2019 :
    Dear All, I have a One Plus 7 device recently bought and the Auto Rotate is not working after the recent software update. Please help me in fixing the problem. Thank you.
