One Plus 7 Pro Camera Delay Lag Issue
  1. anhadkashyap
    Cupcake Aug 7, 2019
    anhadkashyap , Aug 7, 2019 :
    Dear Team,
    am facing lot of issues with the One Plus Camera as it's v ry slow and has lag. this leads to partially blurred images.
    I find this performance very low compared to one plus 3t.
    kindly help!
    thanks
    anhad
  2. pablofg1978
    Spanish POC Assistant Head Moderator Aug 7, 2019
    pablofg1978 , Aug 7, 2019 :
    This is a community forum, not support. There is no team here.
    In which conditions you face lag?
    Can you share an example?
  3. anhadkashyap
    Cupcake Aug 7, 2019
  4. pablofg1978
    Can you answer what I asked before? In which conditions this is happening? Low light? Auto or manual mode?
  5. anhadkashyap
    Cupcake Aug 7, 2019
  6. daninlad25
    Cupcake Jan 11, 2020
    daninlad25 , via OnePlus 7 Pro , Jan 11, 2020 :
    facing similar issue ima facing lag when i open camera app and evend switching between lenses, and when try to take portrait pic camera automatically shuts down
  7. N1565182386590
    Cupcake Jan 14, 2020 at 6:10 PM
    N1565182386590 , via OnePlus 7 Pro , Jan 14, 2020 at 6:10 PM :
    I'm facing similar issues. I've read around and there's supposedly a solution of using Google camera which when installed works but it's unstable. crashes in most unpredictable moments.
    this phone is loaded with brilliant hardware, but the software for the camera falls behind. I hope this will be fixed.
