One Plus 7 Pro Display Burn! Fix? via OnePlus 7 Pro
  1. sahillangoo
    Cupcake May 15, 2021
  2. BeingIncog
    Nougat May 15, 2021
  3. J4t1np4r3kh
    OnePlus Accessory Tester May 16, 2021
    J4t1np4r3kh , May 16, 2021 :
    Contact OnePlus Support to get it replaced. Or learn to live with it, they're your only choices really 🤷‍♂️
    sahillangoo likes this.
  4. Liehjan
    Marshmallow May 17, 2021
    Liehjan , May 17, 2021 :
    You have to replace the screen... And if you do, you should also play less PUBG mobile as screen burn in will eventually come back.
  5. sahillangoo
    Cupcake May 17, 2021
    sahillangoo , via OnePlus 7T , May 17, 2021 :
    Thanks 👍
