one plus 7 Pro display
  1. Nikesh9895
    Cupcake Jul 19, 2020
    Nikesh9895 , Jul 19, 2020 :
    Hello there,
    I recently found some image ( something round ) on the left side top and some writing says " live || killed 0 " like something on the right side - this can be seen when we take some thing with white background like it's underneath it.
    not sure if this was there in the beginning or recent or iam noticing it only now?
    can you please advice?
    O1597310645748 likes this.
  2. spot01
    Ice Cream Sandwich Jul 19, 2020
    spot01 , Jul 19, 2020 :
    It's called "burn in" caused by keeping a static image on screen for an extended period and well known for AMOLED displays
    flither likes this.
  3. Nikesh9895
    yea thanks, I just googled about it now.
    omgggggg!!! my phone is hardly an year old and display started to disintegrate already?? that's very bad ☹️
  4. Artemus.
    Nougat Jul 19, 2020
    Artemus. , Jul 19, 2020 :
    That happens when you let the phone keep a static image on the screen for long periods of time. PUBG needs to rectify this.
    Remember the plasma TV craze? (Or was that not a thing in your country?)
    luigimario and flither like this.
  5. Nikesh9895
    btw, how did u know it was pubg? after you said, I looked in closely and yes it's written like " Alive 20 Killed " omgg!
    but am not a regular user of this game., but yea plays like an hour in a day.
  6. Nikesh9895
    whatsoever, isn't it bad for happening this on such a flagship phone display like this one within a year of use??[e]1f62d[/e][e]1f62d[/e]
  7. Artemus.
    Nougat Jul 19, 2020
    Doesn't matter how long you've owned it, it depends on how long the image stays on the screen in the same exact spot that causes this. This is a common problem on all AMOLED screens.
    flither and Nikesh9895 like this.
  8. Nikesh9895
    mm, okay [e]1f614[/e]
    Thanks.
  9. Nikesh9895
    I was using iphone till I switched to OnePlus. Either this or some other app. eventually the display is going to be affected.
    Now, will need to reconsider buying phones with this kind of displays even if its a flagship one.
  10. Nikesh9895
    Cupcake Jul 20, 2020
    Nikesh9895 , Jul 20, 2020 :
    just one more question please, is it covered under warranty? can I get my device or display replaced?
    luigimario likes this.
  11. AralSadee
    Cupcake Jul 23, 2020
  12. W1579010726761
    Cupcake Aug 9, 2020
    W1579010726761 , Aug 9, 2020 :
    sir I wanna ask that which type of glass or cover should be used for one plus 7 pro
    b coz tempered glass is not suitable for it so plzzz tell me
  13. Param Kharoud
    Marshmallow Moderator Aug 9, 2020
    Param Kharoud , Aug 9, 2020 :
    Posting your personal contact info on a public forum is not safe. Post edited.
  14. luigimario
    The Lab - OnePlus 6T Reviewer Aug 13, 2020
    luigimario , Aug 13, 2020 :
    I feel like it isn't covered but call customer support and see what they say.
    You can try to minimise or reverse the damage depending on how bad it is. You could try a screen burn in fixer app. It flashes different colours on the screen to try to even the pixels out, or something like that, I don't know the science.
    Also, are you playing pubg on full brightness? That will cause burn in much faster. I keep my display around 30% brightness unless I'm in direct sunlight and I've never had an issue.
    I hope they will replace the screen for you, or that you can fix the problem. Good luck
    Artemus. likes this.
