one plus 7 pro incompatibility with amazfit GTS
  1. T1543047260435
    Cupcake Nov 13, 2019
    T1543047260435 , Nov 13, 2019 :
    I have a one plus 7 pro with the latest version via OTA of the oxygen system is based on Android 10 and it turns out that it must be incompatible with the amazfit GTS SmartWatch and also with the Huawei watch GT since I have been unable to synchronize the phone with the SmartWatch since at no time it detects ... I do not know if someone else happens but to me and I wanted to know to see if someone has any solution I have tried to install it on another phone with a lower operating system and if it works but in mine no...thx
  2. Gav_W86
    Moderator Moderator Nov 13, 2019
    Gav_W86 , Nov 13, 2019 :
    check with the people who make it whether their software works with Android 10.
  3. Omkar_Wakhare
    Cupcake Dec 4, 2019
    Omkar_Wakhare , Dec 4, 2019 :
    You may find this crazy but I had the same problem and I was looking for the answer and someone answered, put the watch on your wrist and then try. I tried with no hope and it worked😅😅😅. Or try to scan the code from different angles. And tell me if it worked or not so we can help more peoples.
    kmeli88 likes this.
  4. Go2akram
    Cupcake Jan 13, 2020
  5. borusse1977
    Eclair Jan 13, 2020
  6. M1555887885035
    M1555887885035 , Jan 13, 2020 :
    I have the Amazfit GTR and it paired seamlessly with the OP7 Pro. No sync issues as well. Just make sure to exclude the Amazfit app from OOS's battery optimization.
  7. kmeli88
    Cupcake Jan 14, 2020
    kmeli88 , Jan 14, 2020 :
    This is true! I almost gave up hope when trying to sync my Oneplus 7 pro with my Amazfit GTS, but then I read somewhere that you have to put the watch on your wrist. I did and finally managed to sync, unbelievable!
