One Plus 7 Pro - Warp charge or Rapid Charge Not Working via OnePlus 7 Pro
  1. A1570281700928
    Cupcake Jun 12, 2021
    A1570281700928 , via OnePlus 7 Pro , Jun 12, 2021 :
    Hi,
    After the recent android update, One Plus 7 Pro - Warp charge or Rapid Charge Not Working. I know it's not my charger or cable, I checked it on my wife's one Plus 7 T phone.
    Please help.
    Thanks,
    Shirish
  2. Shailender Sharma
    Nougat Jun 12, 2021
    Shailender Sharma , Jun 12, 2021 :
    Try to disable Optimised Charging in the Battery Settings.
    Also try to Clean the USB Port -
    Charging problems may be caused by debris blocking the physical connections in the charging port. Dirt, dust and lint can get between the metal pins of the charging cable and charging port, preventing electricity from flowing. If this is the case, gently swab the connection port with a toothpick to remove any debris. Be careful not to damage the connector pins.
    Artemus. and Aaron2017 like this.
  3. A1570281700928
    Thanks for the reply Shailendra but it does not seem to be working.
  4. Shailender Sharma
    Nougat Jun 12, 2021
    Check the cable for any possible breakage, also try different power outlets.
    Aaron2017 and Artemus. like this.
  5. devakarthik
    Cupcake Jun 13, 2021
  6. C1575013852326
    Cupcake Jun 15, 2021
