2
one plus 7t battery via OnePlus 7T
  1. Funjaybaba
    Cupcake Oct 30, 2019
    Funjaybaba , via OnePlus 7T , Oct 30, 2019 :
    Hi people,
    just got an 7T and it's an amazing phone, just one problem I m facing and that's the battery, it's draining like crazy. Any one facing same issue any way to sort this other than shifting the phone to 60ghz.
    TIA
    kvnreddy and ASHISH K S like this.
  2. Funjaybaba
    Cupcake Nov 1, 2019
    Funjaybaba , via OnePlus 7T , Nov 1, 2019 :
    update it's second day and I feel it's getting better now the battery is at least lasting for approximately 24hrs compared to 13 hrs on the first day.
  3. Joel A.
    Donut Nov 3, 2019
    Joel A. , via OnePlus 7T , Nov 3, 2019 :
    Hi, I have gone with dark mode on the phone and force dark in developer options (makes all apps in dark mode)....my battery is giving excellent performance. I am using 90hz always.....
    Additionally, the apps which u generally open occasionally and don't use often, go to battery settings and put it as optimize for these apps....
    Use the gray scale tile option when battery is below 10% and u don't have your charger.....
  4. Horsault
    Moderator Moderator Nov 3, 2019
    Horsault , Nov 3, 2019 :
    After an update, your device must optimize itself and its apps, rebuild its cache, and this takes some time running in background, thus draining battery. This is normal process.
