one plus 7T issue/problem via OnePlus 7T
  1. Mangi7
    Cupcake Oct 13, 2019
    Mangi7 , via OnePlus 7T , Oct 13, 2019 :
    1) double tap wake up don't work
    2) some time you fill mobile working leg
    3) gesture problem not comfortable like compare OnePlus 6
    4) heating problem
    5) pdf file not supported OnePlus 6 supported but 7T not supported because it's flagship
    Very bad software pls give me fast update otherwise i can't settle ( Never settle)
    Q1570452256594 likes this.
  2. Horsault
    Marshmallow Moderator Oct 13, 2019
    Horsault , Oct 13, 2019 :
    2) what is a working leg exactly? Personnaly I have 2 legs, but my phone doesn't have any.
    3) what differences don't you like exactly?
    4) when? how?
    5) There never was any pdf reader included in OnePlus devices on OxygenOS.
    khalid123 likes this.
  3. Mangi7
    Cupcake Oct 14, 2019
    Mangi7 , via OnePlus 7T , Oct 14, 2019 :
    2 ) when i use whatsapp videocall after i try other person chat then not open whats app i fill mobile leg
    3) gesture problem like back button . earlyer i was use OnePlus 6 back button down to up and here 7t right to left ya left to right it's good new idea but when open keyboard and you try to back some time hard
    4) when i play pubg heating mobile
    5) OnePlus 6 include supported pdf viewer without third party app
  4. N1571022381866
    N1571022381866 , Oct 14, 2019 :
    - double tap to wake not working
    - Raise to wake not working
    - littttle heating issue while charging
  5. Horsault
    Marshmallow Moderator Oct 14, 2019
    Horsault , Oct 14, 2019 :
    2) This is known WhatsApp problem (see existing threads), so it's on them to correct
    3) You can still use virtual buttons, but when you're accustomed to gestures, it's difficult to go back
    4) What a surprise! Pubg is notoriously power hungry and ressource wasting. See existing threads.
    5) If you say so... I'm pretty sure of the opposite, since I had to install pdf file viewer app on mine.
  6. shuvam3005
    Gingerbread Oct 14, 2019
    shuvam3005 , Oct 14, 2019 :
    I am not sure if this is an issue but when I opted for gesture navigation and opted to turn off the bottom bar. The swipe to switch app were not working and I had to turn on the bar back on to get that to work again.
  7. G_manmath_singh_Charan_r , via OnePlus 7T , Nov 10, 2019 :
    same concerns
