One Plus 7T's Big Problem?
  1. ayushhjaiswal
    Cupcake Sep 10, 2020
    ayushhjaiswal , Sep 10, 2020 :
    I just bought a new 7T and I was shocked to witness the unannounced reboot of the phone while performing simple tasks. It happened twice during a span of 4 hours.
    Do I need to worry?
    How am I supposed to solve this?
  2. Praty_28
    KitKat Sep 10, 2020
    Praty_28 , Sep 10, 2020 :
    Doesn't look normal to me, any app you installed lately after which this started happening?
    ayushhjaiswal and Liehjan like this.
  3. ayushhjaiswal
    I have installed Sticker.ly and IIFL Markets recently.
  4. dalekrebs
    Eclair Sep 10, 2020
    dalekrebs , via OnePlus 7T , Sep 10, 2020 :
    Not normal... I've never experienced an unannounced reboot. And, only rebook initiated by my phone has been in conjunction with an OS update.
    OnePlus 7t
    ayushhjaiswal likes this.
  5. ayushhjaiswal
    The worst part is, I've no idea how to solve this. Neither can I find any support from the Internet.
    Hope the community helps!
  6. #6
  7. jontalk
    Honeycomb Sep 10, 2020
    jontalk , Sep 10, 2020 :
    While I don't own the same phone, I feel confident in saying the problem is most likely related to third party apps so I'd start there if I were you. Try disabling or removing the ones mentioned, clear the system cache and see if the rebooting persists.
  8. ayushhjaiswal
    There is no heating problem.
  9. ayushhjaiswal
    Sure, I'll perform those steps.
    Hope it doesn't happen again.
    jontalk likes this.
  10. Praty_28
    KitKat Sep 11, 2020
    Praty_28 , Sep 11, 2020 :
    Even i have Sticker.ly installed on my phone and it hasn't caused any problems, try removing IIFL Markets and wait for a day or two to ensure that there aren't any more random reboots.
    If at all it happens again I'd suggest that you reboot your phone into safe mode and use it for some time. As all 3rd party apps are disabled in safe mode you can eliminate the chances of 3rd party apps causing random reboots to zero.
  11. #11
  12. ayushhjaiswal
    Cupcake Sep 12, 2020
    ayushhjaiswal , Sep 12, 2020 :
    Yes, I've updated my phone to the latest version of Oxygen OS.
  13. bobsta , via OnePlus 7T Pro McLaren Edition , Sep 13, 2020 :
    Seems to indicate a hardware issue if you tried all the other steps. Contact OP support or if you bought the phone from another retailer I would ask for a replacement or refund.
  14. An.I.Am
    Jelly Bean Moderator Sep 13, 2020
    An.I.Am , Sep 13, 2020 :
    This. It's not normal whatsoever have it checked by customer support
    https://onepl.us/support
  15. Rajendra.Bhat
    Gingerbread Sep 14, 2020
