one plus 8 connect to tv with usb ??? via OnePlus 8 T-Mobile
  1. #1
  2. tide1109
    Jelly Bean May 13, 2020
    tide1109 , via OnePlus 7T , May 13, 2020 :
    Yes, you can.
    You need a USB Typ-C to HDMI adapter, hub or cable. With that you can connect the phone over HDMI to your TV or other display. You TV doesn't need to be smart. It's used as simple display.
    It's not possible with an USB data cable (USB Typ-C to USB-A).
  3. #3
  4. hermit in the woods
    Cupcake Mar 2, 2021
    hermit in the woods , Mar 2, 2021 :
    Connected my OnePlus 8 to my TV via USBC to HDMI, and Netflix plays perfectly for about a minute. Then the screen goes black. After that the TV shows this message: "unsupported signal"
    A solution would be much appreciated!
    (USB debugging has been enabled)
