One plus 8 system crash problem via OnePlus 8
  1. KonradWelenc
    Cupcake May 17, 2021
    KonradWelenc , via OnePlus 8 , May 17, 2021 :
    Hi guys, I have problem with my phone. One plus 8, android 11. Sometimes system crash and my phone is not responding. Then I have to turn it on again. There will also be times when the system error shows up. This is annoying.
    Tried factory reset, did not help. Any suggestions as to what could be the cause? The problem has been around for a long time, with varying frequency.
  2. TheMystic
    Lollipop May 17, 2021
    TheMystic , May 17, 2021 :
    This problem is most likely caused by an app(s). Find out which one it is and uninstall it.
    Alternatively, factory reset and install only the most essential apps. Observe your phone for a couple of days. If the error doesn't show up, install the next set of apps that are useful to you and observe the phone for another couple of days...
    KonradWelenc likes this.
  3. Boki95
    Froyo May 17, 2021
  4. KPlusUK
    Honeycomb May 17, 2021
  5. zupy
  6. V1616873765393
    Cupcake May 18, 2021
    V1616873765393 , via OnePlus 8 , May 18, 2021 :
    This gives me hope that the next os update will stabilize these issues
