giteshsharma007 , via OnePlus 8T , Jan 12, 2021 : I have been using 8T since last week, but don't know why every morning when I unlock my phone display got freezed nothing will work. Again I locked and unlocked my phone then slowly it will open apps then again not responsive finally I have to restart my phone. I have been restarting my phone since 3 days. I had used oneplus 7 before this it never happened with that. I am in real shock why 8T is getting hanged a lot, it doesn't suit OnePlus. Please guide
F_Aidana_Shagalakova_IHC , via OnePlus 8T , Jan 13, 2021 : I bought my OnePlus8T last week, before was using OnePlus 6 since the launching day... And now i m quite disappointed cause the same issue appeared two-three times just in one week Finally was able to capture it.... And to be honest i dont find any difference in speed of my 6 with 8T version
keet1994 , via OnePlus 8T , Jan 13, 2021 : Do you run last update of the launcher? And last update of oxygen os?
psygarden , via OnePlus 8T Aquamarine Green , Jan 13, 2021 : Try to reset the device. But make sure to backup your data first.
Xcommunicad0 , via OnePlus 8T , Jan 13, 2021 : Unfortunate but Factory Reset seems better option, preferably report to OnePlus support team as well.
Amogchilupuri , via OnePlus 8T , Jan 14, 2021 : Me too facing the same issue although I updated to the latest version
R1605366306219 , via OnePlus 8T , Jan 14, 2021 : Can you please tell me if your phone was already updated when u were having this issue. What was uyour oxygen os verisiom when your phone was hanging.
F_Aidana_Shagalakova_IHC , via OnePlus 8T , Jan 14, 2021 : Yes it was updated next day after i bought it, and again, the same situation of freezed display and super slow response abd after this message " system Ui is not responding"
DarshanMeniya , via OnePlus 8T , Jan 15, 2021 : Kindly do hard reset of your phone and if it still doesn't work than got to this section and submit your feedback: https://forums.oneplus.com/feedback/
R1605366306219 , via OnePlus 8T , Jan 15, 2021 : I'm having this same version on my 8t but I'm not facing this issue. I think after updating this will be gone. You should update your os.
R1605366306219 , via OnePlus 8T , Jan 15, 2021 : May be your phone freezes bc of using dual sim. I'm not saying that you shouldnt use both of your sims but you should try to use one sim and see what happens if it still persists then updating is the only solution.
giteshsharma007 , via OnePlus 8T , Jan 15, 2021 : Thanks I have submitted my request they told me sent logs I did that, let's hope for the best
rizwanqureshi786 , Jan 16, 2021 : Please update your phone software to latest version. It seems that your some system file are crashed
giteshsharma007 , via OnePlus 8T , Jan 16, 2021 : Shared Logs with OnePlus feedback team, waiting for their reply, Will do hard reset day after tomorrow. Thanks !
giteshsharma007 , via OnePlus 8T , Jan 16, 2021 : Did hard reset yesterday still the problem exists shared logs with OnePlus feedback team
psygarden , via OnePlus 8T Aquamarine Green , Jan 17, 2021 : I see you have tried a lot of solutions but still facing the problem. I'd suggest to make a fresh install of OOS. Check this thread : https://forum.xda-developers.com/t/...estore-your-device-to-oxygenos.4180837/page-9 But be careful and read all instructions before proceeding. I don't know if it'll fix the issue but it's worth a try.
