One plus 8t wire connection with pc via OnePlus 8T Aquamarine Green
  1. #1
  2. G_Mr_....
    Jelly Bean May 18, 2021
    G_Mr_.... , via OnePlus 8T , May 18, 2021 :
    Hi I had the same issue, you'd never guess how simple the fix was, just turn the type C connection around, the part that you plug into your phone just turn it around & it will work.
    I know it sounds stupid but give it a try & you will see for yourself.
    abidbunny and .Deleted_Member. like this.
  3. abidbunny
    Ice Cream Sandwich May 19, 2021
    abidbunny , via OnePlus 8T , May 19, 2021 :
    You are right, I already experienced it with type C otg and 3.5 to type C adapter, if you are using original oneplus or other branded cable then it works both sides, but if you are using cheap non brand cable then it seems to be works from one side only,
    Keep this joined side upward.
  4. G_Mr_....
    Jelly Bean May 19, 2021
    G_Mr_.... , via OnePlus 8T , May 19, 2021 :
    I was using the official oneplus cable I got with my 8T.
