One Plus 9 Pro Hotspot Issue via OnePlus 9 Pro
  1. Sharma_Shubham_95 , via OnePlus 9 Pro , Nov 28, 2021 :
    I m not able to connect my Phone's Hotspot with my laptop's wifi.
    The laptop recognises the hotspot but upon entering the password the error states 'cant connect to network'
    I have already tried it at WPA-2 and wifi standard 6 but have not been able to connect it.
    I was using One Plus 6 before this and it worked smooth with my laptop.
    Kindly resolve or suggest solutions.
  2. N1600417325693 , via OnePlus 9 Pro , Nov 28, 2021 :
    First check forget the network on your laptop than reset your hotspot password and try to reconnect it on your laptop.If that doesn't work see whether your laptop connect to other hotspot than run troubleshoot.If still it doesn't work back your phone and reset it.
  3. pgrey
    Ice Cream Sandwich Nov 28, 2021
    pgrey , Nov 28, 2021 :
    Do you have 802.11ax, on the laptops' side?
    If not, you'll have to down-level the settings as such, or it won't be able to connect (the OP 9 doesn't support dual-mode, at least as far as I know, not sure any phone does...).
  4. Sharma_Shubham_95 , via OnePlus 9 Pro , Nov 29, 2021 :
    It is LAN 802.11n and not ax. Can you please explain as to what settings to be downgraded? I have WPA-2 and 6.0 is also switched off. My laptop used to work fine with one plus 6.
  5. Sharma_Shubham_95 , via OnePlus 9 Pro , Nov 29, 2021 :
    Thank you, but I ve tried all of this a lot of times but nothing helped
  6. H1638170798914
    Cupcake Nov 29, 2021
    H1638170798914 , Nov 29, 2021 :
    1.
    First of all check that you have 3G / 4G / 5G mobile connectivity activated on your OnePlus 9 Pro. To do this, with the OnePlus 9 Pro unlocked, you can.
    2.
    On your OnePlus 9 Pro go to the device settings, it is the gear wheel icon that you will find on the home screen or in the phone menu, you can access the.
    3.
    Click on “Networks & internet” or “Connections” and then click on “More”.
    4.
    Alaska Employee PET Login
  7. pgrey
    Ice Cream Sandwich Nov 29, 2021
    pgrey , Nov 29, 2021 :
    I thought you were saying you had the "WiFI 6 AP" switch set, which would definitely make a mess of this scenario.
    I'd remove the space from your hotspot name, call it say "Pro_9", or similar.
    Then, go to your Windows machine (laptop), and "Reset Network Settings", by going to "Settings -> Network & Internet -> Network Reset".
    Keep in mind this will remove ANY/ALL previous WiFi connections, AND your Bluetooth pairings. It will often fix this issue though, because it thoroughly flushes the cache of the named networks...
    Sharma_Shubham_95 likes this.
  8. Sharma_Shubham_95 , via OnePlus 9 Pro , Nov 29, 2021 :
    Thanks for patience. I tried the above steps and once it got connected but now again it is showing the same error. I tried the above step again of resetting network but now it is not connecting.
    How can it connect once and now again repeating 'can't connect' error?
    It is super confusing.
  9. pgrey
    You're talking about an error, on the laptop side, correct?
    What's the actual error (numbers help a LOT here, numeric error values)? If you're not seeing it, the EventViewer will have more info, you just have to look at "System Events" and find the errors around the timing for your connection attempt.
    Also, you're saying it worked, after the reset, and then didn't? Can you be more specific?
