One plus Buds pro connectivity issue
  1. ChetanMisra
    Cupcake Sep 25, 2021
    ChetanMisra , Sep 25, 2021 :
    Hi, I have just bought One plus Buds pro yesterday and trying to connect with my One plus Nord 2. There is no issue in connectivity however not able to find earbud functions activated to control settings of buds....Page stucks after taking it to "About" page & then Blank...Pls help....
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Sep 25, 2021
    Dresa91 , Sep 25, 2021 :
    Can you please check, if you are using the latest version of the OnePlus Buds app?
    https://play.google.com/store/apps/details?id=com.oneplus.twspods
    check if there is an internet available in PlayStore.
    if not, please install the latest version of the Buds App from https://www.apkmirror.com/apk/oneplus-ltd/oneplus-pods/
  3. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Sep 26, 2021
    Liehjan , Sep 26, 2021 :
    You need buds app 1.3.6... what's your version?
    ChetanMisra and Dresa91 like this.
  4. Dresa91
    User of the Year 2016; Most Active User 2020 Sep 26, 2021
    ChetanMisra and Liehjan like this.
  5. Liehjan
    I know, just wanted to make it clear that it's version 1.3.6 that is the newest one. If OP is using community app link's don't work :p
    Dresa91 likes this.
  6. ChetanMisra
    Cupcake Sep 26, 2021
    ChetanMisra , Sep 26, 2021 :
    Yes, It worked.. Many Thanks...But the app is not visible in App gallery...is it right ?
    Also no option of any sound setting like reducing bass etc...
  7. ChetanMisra
    Yes, its working after App update...Thanks for reply...
    Liehjan likes this.
  8. Liehjan
    Great! :)
    Dresa91 likes this.
  9. Dresa91
    Dresa91 , Sep 26, 2021 :
    You are welcome:)
