One Plus bullets wireless Z via OnePlus 8 Interstellar Glow
  1. Rc9279 , via OnePlus 8 Interstellar Glow , Apr 13, 2021 :
    Sometimes I am facing problem in connecting with my one Plus wireless bullet z. I can not hear voice call sometime in bullet z. I am not satisfied with this technical error. I can not hear call sometimes while connecting bullet z.
    Pls fix this issue.
    zain.h likes this.
  2. NaXal
    Honeycomb Apr 15, 2021
    NaXal , via OnePlus 8T , Apr 15, 2021 :
    Hello,
    Usually when someone is facing Bluetooth issues, few things to try one at a time,
    1. Reboot both the devices. A simple reboot solves so many issues.
    2. If that doesn't help, delete all paired devices, reboot & reconnect / pair your Bluetooth to check.
    3. If that doesn't help, back up all the data & do a factory reset of the phone and reconnect the Bluetooth to check in a fresh device.
    4. If that doesn't help, then I guess it's time to contact OnePlus customer care for further troubleshooting & if needed then warranty claim.
    Thanks.
    Rc9279 likes this.
  3. Tee_Eee_Bee
    Ice Cream Sandwich Apr 16, 2021
    Tee_Eee_Bee , Apr 16, 2021 :
    If you haven't done it already, try resetting your Bluetooth adapter and see if that makes any difference:
    Settings > System > Reset options > Reset Wi-Fi, mobile & Bluetooth
    NaXal and Rc9279 like this.
