One Plus Equivalent Tablets - Cheap, high spec etc.
  1. chris-red
    Gingerbread Jan 20, 2016
    chris-red , Jan 20, 2016 :
    Hi all, anything like OnePlus in the tablet world? I'm after a decent Android tablet for my Girlfriend.
    What do you think the best Chinese Tablet is?
    Lingering likes this.
  2. Alivethereality
    Jelly Bean Jan 20, 2016
    Alivethereality , Jan 20, 2016 :
    i could recommend Amazon's fire tablet
    it costs 50$, and its pretty powerful for the price
    all you gotta do it root it and change launcher, because without root its not worth the money cuz its useless
    benluca and mattylew80 like this.
  3. mattylew80
    Honeycomb Jan 20, 2016
    mattylew80 , Jan 20, 2016 :
    I agree. I have a kindle fire hd that I turned into an android tablet, CM 12.1 on it. I love it, great alternative to buying an expensive tablet.
  4. aenews
    KitKat Jan 23, 2016
    aenews , Jan 23, 2016 :
    It's Android to start with... Just a different launcher, but that's an easy change. Install GAPPs then it's just another skin like TouchWiz. But yeah CM is much better than Stock ROM...
  5. aenews
    KitKat Jan 23, 2016
    Best Tablet Out: Pixel-C
    Nvidia Shield Tablet [K1] has a pretty reasonable price for the firepower (TK1 is faster than S810) at $199.
    IvanMuse and Tokolozi like this.
  6. gringoboy
    Lollipop Jan 23, 2016
    gringoboy , Jan 23, 2016 :
    Mi pad 2 is pretty cheap and getting some decent reviews, but it's not long out.
  7. stacymilne
    Eclair Jan 23, 2016
    stacymilne , Jan 23, 2016 :
    I really want Oneplus to make a tablet:
    8" ish;
    3 + GB of ram;
    decent CPU(SD810, kirin 950, even the intel, z8500?);
    amoled of OLED screen;
    sdcard slot; and
    a good battery (hell, make it removable! shake up the industry!)
    These specs with OxyenOS very Vanilla android UI would make a perfect tablet.I do not need super thin glass or expensive aluminium, give me sandstone plastic back! cause I will just put a case on it anyway,
    I personally would buy the Dell Venue 8 7000......if it had 3GB of ram. OnePlus if you read this. Build a Dell Venue 8 7000 clone with more ram and oxygen OS(with sexy dark theme). <- yes, this tablet as the fancy aluminium construction, but if it had more ram and less metal, I would still buy it!/>
    I patently await my invite to buy said tablet.
    IvanMuse likes this.
  8. aenews
    KitKat Jan 23, 2016
    That's not a good tablet. Shield Tablet is better (TK1>S810) and carries those traits except the screen and 2GB RAM.
  9. rphlfjrd
  10. stacymilne
    Eclair Jan 23, 2016
    What is not good? I am not a gamer, mostly just read... with ten zillion tabs(ram).
    I did look at the shield tablet, but the ram and screen kind of kill it for my needs
    atiq.qasim.12 and IvanMuse like this.
  11. aenews
    KitKat Jan 23, 2016
    Then get the Pixel-C :eek:
    rphlfjrd and IvanMuse like this.
  12. stacymilne
    Eclair Jan 24, 2016
    stacymilne , Jan 24, 2016 :
    The pixel c is a little bit too big. Again, looking for that seeminlgy unicorn tablet at the 8" ish size.
    Unless the pixel c only looks big? The comparisons make it look kind of square... Not my optimal rectangle reading shape.
    S
  13. 5thban
    Gingerbread Jan 24, 2016
    5thban , Jan 24, 2016 :
    there is a lot of great options you can get from china lol. just look up ebay or amazon. you should find smth good.
    stacymilne likes this.
  14. ppod
    Jelly Bean Jan 24, 2016
    ppod , Jan 24, 2016 :
    If your a reader then (and i will say it 3 times just so it sinks in) "Aspect Ratio, Aspect Ratio, Aspect Ratio"
    Phew that was a lot of typing.
    Tokolozi likes this.
  15. aenews
    KitKat Jan 24, 2016
    aenews , Jan 24, 2016 :
    I have a Project Tango Tablet (128GB Internal Storage, 4GB RAM, microSD, microUSB, USB 3.0, 7-Inch Display, Tegra K1). It's not really worth twice the price of the Shield Tablet, but maybe you can find one on sale. It's technically a developer's tablet with 3D Mapping capabilities.
  16. Tokolozi
    The Lab Reviewer - OPPO Find N Jan 25, 2016
    Tokolozi , Jan 25, 2016 :
    If it's mainly for reading d go for a kindle tbh, but Web reading is a different story.
  17. stacymilne
    Eclair Jan 25, 2016
    stacymilne , Jan 25, 2016 :
    I will check it out. Still kind of leaning toward the dell. As other people have mentioned. Aspect ratio is important for reading. I just worry that Android and 2gb of ram is going to be laggy(the dell venue 8 7000)
    Thanks to all for the coments and advice
  18. ppod
    Jelly Bean Jan 25, 2016
    ppod , Jan 25, 2016 :
    Have you done anything interesting with your Tango yet?
  19. aenews
    KitKat Jan 25, 2016
    aenews , Jan 25, 2016 :
    Haven't done much with it but fool around with the applications and Root it.
  20. stacymilne
    Eclair Jan 25, 2016
    Ya, I was actually looking at the huawei m2.
