One plus nord 5g connection issue via OnePlus Nord
  1. An0sh
    Cupcake Dec 1, 2021
    An0sh , via OnePlus Nord , Dec 1, 2021 :
    Hi team I am using one plus nord and I am unable to connect to the 5g network at some times, when I try to connect I get the message "failed to connect to network". The issue is intermediary, some times I am able to connect to the 5g network. I had seen many threads with the same issue being reported
    Kindly do the need full
  2. Shailender Sharma
    Nougat Dec 1, 2021
    Shailender Sharma , Dec 1, 2021 :
    Try to Reset WiFi, Mobile & Bluetooth -
    Settings - System - Reset Options - Reset WiFi, Mobile & Bluetooth.
    It might help.
    Also, provide your feedback directly to the OnePlus Developers team Here
    How to report a bug and share your product suggestions on OnePlus community? Here
  3. An0sh
    Cupcake Dec 1, 2021
    I tried to reset but still having the issue. After the reset when I tried to connect to the 5g network I got the message "failed to connect"
  4. Shailender Sharma
    Nougat Dec 1, 2021
    Have you tried to contact your ISP support?
    OnePlus Nord has only one 5G band, N78.
  5. An0sh
    Cupcake Dec 1, 2021
    No but if this was an issue of unsupported feature the device will not connect to the 5g band at all, in my case it connects at times and does not
  6. Shailender Sharma
    Nougat Dec 2, 2021
    Shailender Sharma , Dec 2, 2021 :
    In my opinion the OnePlus support should answer this question.
    Contact OnePlus support Here
  7. B1635836576634
    Cupcake Dec 2, 2021
    B1635836576634 , Dec 2, 2021 :
    I have a same device and same issue while using this device only but when I connect 5G with another device here it looks all right.
  8. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Dec 2, 2021
    Liehjan , Dec 2, 2021 :
    Just to make things clear here, are you talking about WiFi 5ghz network or mobile 5G network?
    Shailender Sharma likes this.
  9. An0sh
    Cupcake Dec 2, 2021
  10. Liehjan
    Same question for you, are you talking about WiFi 5ghz network or mobile 5G network?
  11. Liehjan
    So there is a confusion here, @Shailender Sharma thought you where talking about mobile 5G.
    In the future it's better to talk about 5ghz instead of 5g when it comes to wifi so there is no confusion :)
    A way you can solve this issue you are having is to split the wifi network into two separate SSID's. One for 2.4ghz and one for 5ghz.
  12. Shailender Sharma
    Nougat Dec 2, 2021
    Thanks @Liehjan for the clarification. 👍 Typical cupcake behavior.:p
