Network/Connectivity
One plus one and smartwatch connection problem
  1. flavus Cupcake Dec 17, 2016
    flavus, Dec 17, 2016 :
    Hello to all
    I have a problem to connect my opo to my smartwatch LG G Watch R.
    I modified the file in the system folder as described in other posts.
    I reset the smartwatch, I connect via bluethoot, the smartwatch update itself and then syncs, but at the end of the process, there is no connection between smartphone and smartwatch. Android wear does not see the smartwatch.
    i Run Tugapower 10 but It is the same also with other ROM Nougat, while ROM Marshmallow everything works ..
    Smartcwatch is equipped with Android 6.1 and Android wear 1.5.0.3505725.
    Thanks for the tips
  2. R1551112456021 Cupcake May 23, 2019
    R1551112456021, May 23, 2019 :
    Were you able to solve the problem with your smartwatch connection? I also bought this phone and I just bought a Mickael Kors but I am not able to connect it.
    Someone who can help me
