7
One Plus One Random Reboots!!! (Is this a common problem?)
Are you facing random reboot problem in OPO?
  1. Yes
    83.0%
  2. No
    17.0%
  1. The1Lion
    Marshmallow Apr 6, 2017
    The1Lion , Apr 6, 2017 :
    I've noticed that - and typically you can tell as some are actually not marked as "new". If the seller has a good rating and feedback seems overall good then I'll get one - it's not that expensive (more the the $8 you paid but still not too bad). From what I've seen, it also seems the hardest part may just be prying the battery out.
    #41
    pa5t1s and Deactivated User like this.
  2. The1Lion
    Probably go with Lineage since I have been using CM on my older HTC and COS on the One. In fact I was going to use Linage on the HTC first just to see how it does but that phone is really old now and only has 16GB - still it's a useful test phone :D
    #42
    pa5t1s and jenish112 like this.
  3. jenish112
    Gingerbread Apr 7, 2017
    jenish112 , Apr 7, 2017 :
    Yeah that sounds like a good plan. :p:D
    #43
    The1Lion likes this.
  4. Deactivated User
    Apr 7, 2017
    #44
    pa5t1s and The1Lion like this.
  5. The1Lion
    Marshmallow Apr 14, 2017
    The1Lion , Apr 14, 2017 :
    Got Lineage up and running now. I got greedy with the OpenGapps and went with Super, didn't work :oops: (Famous Error 7) Lineage installed fine though. So opened a browser on my phone and downloaded the Nano version (ARM 7.1) and viola it worked when I flashed it.
    I enabled Root to restore my TB backups but TB reported no root -even after a restart. So I flashed the SU zip I previously downloaded to get TB to work, that got TB to work again and I did my restore.
    So far so good :D
    #45
  6. vammy
    Eclair Apr 14, 2017
    vammy , Apr 14, 2017 :
    I have started experiencing reboots since 2 days on my OPO. But I see that the reboots don't happen when I have the phone plugged to a charger or a USB port.
    Makes me wonder if it's a battery issue or motherboard issue or some kinda virus hack to ensure they steal my data without a powerloss.... :(:(:mad:
    #46
  7. jenish112
    Gingerbread Apr 14, 2017
    jenish112 , Apr 14, 2017 :
    That's great buddy. Even i am going to flash it soon once i am done with my exams!!
    #47
  8. jenish112
    Try clearing data and cache files. Also uninstall all the apps which you don't use. It might help.
    And best option as many have suggested is to do a factory reset and preferably shift to different ROM.
    #48
  9. F_Yash_Tiwari_wYbL
    Cupcake Apr 14, 2017
  10. Tuler
    Cupcake Apr 21, 2017
    Tuler , Apr 21, 2017 :
    About 2 - 3 times a day
    #50
  11. mushytitan
    Eclair Apr 21, 2017
    mushytitan , Apr 21, 2017 :
    I'll get like, 4 to 5 random reboots in a span of 30 minutes some days, but not that often. I'll get random reboots from time to time, it just started a few months ago for me
    #51
  12. kartike4u
    Ice Cream Sandwich Apr 21, 2017
    kartike4u , Apr 21, 2017 :
    *soft bricked.....hard brick is much worse
    #52
    pa5t1s likes this.
  13. The1Lion
    Marshmallow Apr 21, 2017
    #53
    prax and pa5t1s like this.
  14. varunkhanna21
    #54
  15. akhetaton
    Honeycomb Apr 21, 2017
    akhetaton , Apr 21, 2017 :
    I personally recommend to switch to Resurrection Remix, if you're going to root your phone. I was on that ROM for the last year of life of my OPO and couldn't be happier (good battery life, perfect OMS integration since Nougat and a huge load of customization available)... Only the premature death of my OPO led me to swap for 3T (OPO fell into a river and bye bye)
    #55
  16. The1Lion
    The1Lion , Apr 21, 2017 :
    Had to open my mouth! Noticed the screen light up at one point today and assume it was a reboot (saw the startup animation) - but at least it was quick! :p It only flashed briefly then the lock screen appeared.
    Odd that it's behaving this way after such a long time.
    #56
    pa5t1s likes this.
  17. G_Rohan_Patre_hiZT
    Gingerbread Apr 23, 2017
    #57
  18. prax
    Cupcake May 8, 2017
    prax , May 8, 2017 :
    Have been using OPO since December 2014 and have been having this random reboot issues since last 4-5 months. Reboot frequency has increased to once a day from a month or so. using Cyanogen OS 13.1.2 On previous occasions have tried clearing cache and also removed few apps that i thought were hanging....disappointed :( looks like I will have to move to a different OS.
    #58
  19. prax
    Cupcake May 10, 2017
    prax , May 10, 2017 :
    Hi, Hows it with Lineage OS now? Does the random reboot issue recur or is it gone?
    #59
  20. The1Lion
    Marshmallow May 10, 2017
    The1Lion , May 10, 2017 :
    Funny you should ask as I was just thinking this morning I haven't noticed it for some time. With COS when it happened it took a while to complete the reboot, but the one time I noticed with Lineage, it was a lot faster recovering from the reboot. For me it only seemed to happen while the phone was not in use, it never rebooted while I was using it; for both COS & LOS
    #60
