One plus phone call issue via OnePlus Nord
  1. B1597946958562
    Cupcake Apr 19, 2021
    B1597946958562 , via OnePlus Nord , Apr 19, 2021 :
    During phone call i can not hear anything in upperspeaker but when I turn on loud speaker I mean bottom speaker I can hear them this happens many time but this time it is not at all getting back to normal ,it means I am not able to call to anyone pls fix this issue as soon as possible .
    burman.steve likes this.
  2. B1597946958562
  3. NaXal
    Gingerbread Apr 19, 2021
    NaXal , via OnePlus 8T , Apr 19, 2021 :
    Hello,
    Try whatsapp calling, see if your upper speaker working or not.
    Otherwise, download the OnePlus Care app & run the phone diagnostic.
    If top earpiece isn't working, then hard reset the phone to factory default. Warning, it will delete all data.
    Try without any extra software/app after reset, see if it's working. If there too it isn't working, then you need to contact Oneplus support for repair
    Thanks.
    B1597946958562 likes this.
  4. B1597946958562
    I did whatsapp call also it doesn't work
    I have installed oneplus care and I diognosed earpiece but it is testing the bottom speaker I mean normal speaker NOT the earpeice speaker
    Now I have to do factory reset
    No other way 😓
    NaXal likes this.
  5. B1597946958562
    When I done this
    For both Earpiece speaker and normal speaker it is testing
    THE NORMAL SPEAKER AND NOT TESTING THE EARPIECE SPEAKER!😓😑
  6. Shailender Sharma
    Marshmallow Apr 19, 2021
    Shailender Sharma , Apr 19, 2021 :
    Visit a authorised OnePlus Service center with your device for diagnose and inspection
    Or
    Contact OnePlus support:
    https://www.oneplus.com/global/support/contact
  7. B1597946958562
  8. Shailender Sharma
    Ask OnePlus support to help you send the device to the nearest service center.
  9. burman.steve
    Eclair Apr 21, 2021
    burman.steve , Apr 21, 2021 :
    Same issue here. Tons of us have the issue. We need this fixed asap. A factory reset does NOT fix it! I wasted my time tonight doing that. Android 11 is simply broken for everyone who makes normal phone calls.
  10. Young_Blood
    KitKat Apr 21, 2021
