4
One plus Two battery test
  1. F_Hassnain_Hussain_JyyL
    Cupcake Apr 6, 2017
    #41
  2. Praty_28
    KitKat Apr 6, 2017
    Praty_28 , Apr 6, 2017 :
    The battery temperature in the screenshot you provided is completely normal. I dont see any problems. And my question whats the problem if its heating? Iz ur hand burning? u cant hold it? My suggestion is use gloves while charging.
    #42
  3. Sankethsince1993
    Donut Apr 6, 2017
    #43
  4. Sankethsince1993
    Donut Apr 6, 2017
    #44
  5. abhi2640
    Cupcake Apr 7, 2017
    abhi2640 , Apr 7, 2017 :
    I am also facing the same issue.. It takes 6-7 hrs to get full charge.
    #45
  6. imrana1986
    Cupcake Apr 7, 2017
    imrana1986 , Apr 7, 2017 :
    Change the charging cable, i am facing same issue after the update, so i bought a new cable and issue is resolved now.
    #46
  7. G_Ujjwel_Raj_Shrestha_KE
    Cupcake Apr 7, 2017
  8. G_Ujjwel_Raj_Shrestha_KE
    Cupcake Apr 7, 2017
    #48
  9. gargarc9
    Cupcake Apr 7, 2017
    #49
  10. oyesardarji
    Donut Apr 7, 2017
  11. tanmaysalunke
    Gingerbread Apr 8, 2017
    tanmaysalunke , Apr 8, 2017 :
    no its not ok. Try Oneplus 3 type c cable . You can charge your phone within 1:45 hours . try that
    #51
  12. swamitra
    Eclair Apr 8, 2017
    #52
  13. Suhaibkhan
    Donut Apr 8, 2017
    #53
  14. subhoa2z
    Cupcake Apr 8, 2017
  15. subhoa2z
    Cupcake Apr 8, 2017
    subhoa2z , Apr 8, 2017 :
    Type C USB C to USB A 3.0 6 ft long Nylon Braided Original Mivi Tough Cable for OnePlus 3, OnePlus 2, Nexus 5X, Nexus 6P, Le Eco Le 2, new MacBook, Ch https://www.amazon.in/dp/B01G21GEY6/ref=cm_sw_r_cp_apap_3c8aBKtTIZCy8
    I was also facing problems regarding charging my one plus 2. It is the USB cable which comes with the box is defective. Then I bought this USB cable given in the link. Now my phone takes 2-2:15 hours to get fully charged. It is a nice cable. Just buy it and you will be not disappointed for sure.
    #55
  16. F_Anirudh_Kumar_zkYP
    Cupcake Apr 8, 2017
  17. Deactivated User
    Apr 8, 2017
    #57
  18. amit3dhumal
    Eclair Apr 8, 2017
  19. Jackson george
    Froyo Jul 20, 2017
    #59
  20. Jackson george
    Froyo Jul 20, 2017
    #60
