10
one plus two heating and battery drain .......
  1. govindkrishna
    Eclair Sep 27, 2015
    govindkrishna , Sep 27, 2015 :
    I have updated all my google apps, a day back. I am not sure what you mean by wake locks though. Pardon my lack of indepth knowledge but what does "phone is never awake in a continuum" mean?
    I think I should turn off gestures, like you said - because I am using onePlus's flip cover and gestures do no good since the phone wakes up as soon as I open the flap.
    I have already drained my battery completely and charged with phone off - twice.
    Yeah, agreed - it's an awesome device.
  2. nitin_g3
    Gingerbread Sep 27, 2015
    nitin_g3 , Sep 27, 2015 :
    Awesome wake lock is when phone is in awake condition cause by some app/system process, in your case android system keeps you phone awake the most. And as you can see the line next to Awake on battery history details screen is not a continuous one like in front of WiFi.
    I'm out of suggestions :p
    XDA forums are your Guru now :).
  3. govindkrishna
    Eclair Sep 27, 2015
    Thanks. I will factory reset and find out.
    nitin_g3 likes this.
  4. govindkrishna
    Eclair Sep 27, 2015
    Just did it - didn't realize how much of work it is to get everything synced :oops:
    paulp likes this.
  5. paulp
    Ice Cream Sandwich Sep 27, 2015
    paulp , Sep 27, 2015 :
    Opo is out of stock... In Germany
  6. mwayner
    Lollipop Sep 27, 2015
    pa5t1s likes this.
  7. Spliffman
    KitKat Sep 27, 2015
    Spliffman , Sep 27, 2015 :
    Does it have any bugs? Runs smoothly?
  8. govindkrishna
    Eclair Sep 28, 2015
    govindkrishna , Sep 28, 2015 :
    So I formatted, spend 06 hours reinstalling everything and still stuff left to configure. I am losing battery on idle due to my network coverage. During the day hours the battery loss is less. I had 100% at 1am - 8am its 60%
    This network coverage is strange, because Airtel has very good signal strength here it's always on full and I have data off. Wonder what's happening. Cell Network is taking 73% of my battery in term sof the drain.
  9. nitin_g3
    Gingerbread Sep 28, 2015
    nitin_g3 , Sep 28, 2015 :
    Have you tried inserting sim in another slot? and also try with other provider's sim.
    See what battery stats say when you do this.
    govindkrishna likes this.
  10. dac9
    Cupcake Sep 28, 2015
    dac9 , Sep 28, 2015 :
    This battery issue is very concerning... However, if the update does in-fact fix this it should be noted by an official from OPO.
    I am looking at getting the device for my dad who is a huge traveller... I am concerned these issue with one sim will increase with two sims.
    I myself use Nexus devices so big day tomorrow :)
    Invite needed :) CLICK
    Daniel
  11. shkr
    shkr , Sep 28, 2015 :
    Ur explanation is agreeable but what about the devices which doesnt get heated. Energy is not generated in them :eek:
  12. govindkrishna
    Eclair Sep 28, 2015
    He explained that those devices dissipate heat much more efficiently, which onePlus clearly lacks in some cases.
  13. govindkrishna
    Eclair Sep 29, 2015
    govindkrishna , Sep 29, 2015 :
    Alright forum -
    I somewhat solved this battery drain issue on idle, I don't know if I can call it solution but nonetheless it works for me & it's great.
    Yesterday before sleeping, my charge was at 92% and I set my battery to battery saver mode. When I woke up after 7 hours, it was still at 92%
    Yes I did not receive updates, but my emails were there - alram worked as it should. I don't care about notification, until I am completely awake. It's been close to 20 hours, charge is at 41% right now and I am not charging today :)
    Screenshot attached. If you see my earlier posts with battery stats screenshot, you can see the difference.
    Finally though, I found my solution. Not necessarily a solution for all, especially if you are like my younger brother who wakes up every now and then to check his phone for updates and have improper sleep.
    Hope this helps few people.
    Ionbostan likes this.
  14. playkish
    Cupcake Oct 17, 2015
    playkish , Oct 17, 2015 :
    Battery Draining very fast.Without using any WiFi,without playing any game it drops from
    100% to 87 % within half an hour. My OnePlus 2 have Oxygen OS 2.1.1 . How to resolve it.
  15. Spliffman
    KitKat Oct 17, 2015
    Spliffman , Oct 17, 2015 :
    I personally, and many others, have flashed AK Kernel and idle drain is zero to minimal. You could try that. Search it here, there are a couple good threads on it. I strongly recommend it.
    mwayner likes this.
  16. mwayner
    Lollipop Oct 17, 2015
    mwayner , Oct 17, 2015 :
    Post a shot of Battery stats.
  17. vmohan01
    Cupcake Oct 27, 2015
    vmohan01 , Oct 27, 2015 :
    I agree with govind Krishna. I bought the phone for better battery but I am not getting it. One plus needs to do something. I charge my mobile overnight and it drains in just 5 hrs. If I use LTE the just 3 hrs of battery. I wish I had bought Sony Z series..but I got OPT instead.
  18. Hafiz5635
    Honeycomb Oct 27, 2015
    Hafiz5635 , Oct 27, 2015 :
    Dont stay to long on oxygen, move to HYDROGEN dude.. I recommend you to try it.
  19. vette95
    Froyo Nov 9, 2015
    vette95 , Nov 9, 2015 :
    You sound like my boss when I tell him there's a bug with our system.
    Shuller likes this.
  20. mohsnmhd
    Cupcake Nov 11, 2015
    mohsnmhd , Nov 11, 2015 :
    Same issues here! Rest is fine. but GPS drains the battery.
