10
one plus two heating and battery drain .......
  1. josefn24
    Jelly Bean Sep 17, 2015
    josefn24 , Sep 17, 2015 :
    I have 2 op2s and the battery is amazing and no heating fingerprint is almost perfect both devices are running perfect even in heavy gaming it doesn't get even near as hot as other phone including the OPO. Heating while charging is normal in lots of phones.
  2. Shuller
    Shuller , Sep 17, 2015 :
    tha
    that's not a bug, that's a feature ))
    greatbm and evil11204 like this.
  3. asmh_9
    Honeycomb Sep 17, 2015
    Chetan59 likes this.
  4. locatekrish
    Froyo Sep 17, 2015
    locatekrish , Sep 17, 2015 :
    Its the OS issue only !!! I hope they fix these in OS 2.1 !! Also install CM , to manage the background apps !! You need to make your smartphone, "Smart" so that it can aid you !
  5. govindkrishna
    Eclair Sep 17, 2015
    govindkrishna , Sep 17, 2015 :
    @locatekrish - happy to hear that it's an OS issue and I hope that they fix this too - I am charging twice a day now without using anything apart from whatsapp, call, message, occasional twitter & quora and emails. Dying to play games. Phone heated up quite badly that I got scared - when playing games with charger connected
    I really don't want to change to CM - I love stock android and oxygen is simply elegant (my personal opinion of course). Oxygen does allow me to manage background apps in the 'app' option in settings
    I wonder if onePlus guys are monitoring their forums. I tweeted to them regarding the same but got no reply there.
  6. nabhishek
    Eclair Sep 17, 2015
    nabhishek , Sep 17, 2015 :
    Same issue faced by me too! :)
    Just for a while I switched to battery saver mode and it works more than fine. 2-3% in an hour. At least I can use my phone for calling. Background stuff doesn't work well in this mode though so be careful. This proves problem isn't with the hardware but the software! @Carl OnePlus should come up with the OS update to fix battery issues or let people use Cyanogenmod unofficial OS(officially!).
  7. dash.scibolt
    Donut Sep 17, 2015
    dash.scibolt , Sep 17, 2015 :
    I have a OP2 (INDIA) . It gets heated up pretty badly while playing games and battery drains fast too on 2.0.2. Whereas the tech reviewers say otherwise. Probably they were having the previous builds and I suppose the problem is with the 2.0.2 update. Waiting for 2.1 update.
  8. jizang
    Lollipop Sep 17, 2015
    jizang , Sep 17, 2015 :
    turn off wifi...less drain
  9. Faithfull
    Froyo Sep 17, 2015
    Faithfull , Sep 17, 2015 :
    My Tv gets hot when i use it, my computer gets hot when i use it, my car engine gets hot when i use it, mt GoPro battery gets hot when i use it.......Do you want me to go on? Shall i send all these items back as they 'must be faulty'. Let me introduce to some of you - ''Thermodynamics'' which basically in dumb *** terms = ''So we have this circuit and there's a resistor in it. When electricity flows through, some of it would seemingly get "lost" due to resistance (this is measurable), but the energy isn't lost at all, it's simply changed to a different form of energy: heat.
    vette95, djbestyboyz, IrfanO and 8 others like this.
  10. Rushabh Gohel
    Rushabh Gohel , Sep 17, 2015 :
    Great Explanation.. Hope someone can understand..;)
  11. pratikg88
    pratikg88 , Sep 17, 2015 :
    I have purchased two OP2 and none of it have any type of issues. Although it heated while charging around 40C but it's normal.
    Also I get 20-22hrs of battery backup on dual sim with 3G on.
  12. pratikg88
    N
    Nice one mate
    vette95 likes this.
  13. hadogumu
    Ice Cream Sandwich Sep 17, 2015
    hadogumu , Sep 17, 2015 :
    Same here.
    I have similar experience on my TWO too.
  14. strickerz
  15. mwayner
  16. gurps220
    Froyo Sep 17, 2015
  17. kleinbatavia
    kleinbatavia , Sep 17, 2015 :
    It is normal and was to be expected due to the use of the 810 processor. You can use it to iron your shirts or fry an egg though, which is nice :) Sell the thing to some other fool at retail and buy another phone, you'll thank me for it later :)
    shubhakar1985 likes this.
  18. dash.scibolt
    Donut Sep 17, 2015
    Everything is turned off. NO data, no location, no wifi, low screen brightness. It heats up to an unbearable level while playing Real Racing 3 and while using camera app.
    #38
  19. kleinbatavia
    The issue should not have been an issue if OP had not cut corners and rushed a flawed product to market ;) And from over a year of experience with OP... They will fix one thing, but something else will be amiss...
    #39
  20. dash.scibolt
    Donut Sep 17, 2015
    Which version of Oxygen Os are you using? I updated directly from 2.0.0 to 2.0.2 via a 40 mb software update.
    #40
