One plus two no display
  1. rahulnegi1409
    Eclair Apr 25, 2016
    rahulnegi1409 , Apr 25, 2016 :
    Howdy !!
    I have one OnePlus 2 currently it's display is not working .
    recently It got some water inside it little bit I think ,after that I immediately switched it off (because I know what to do when your phone is in contact with water , then one of my friend turned it on but I switched it off as soon as I get to know he turned it on again back , it was heating little bit more than usual )
    I took it to service center they says its Un-repairable and all .
    But the thing is phone is switching on and off .
    I can feel vibration the vibration of the phone , when I plug the charger it makes sound .
    and it hard keys are working fine as well.
    and it gets locked by hard lock button and I can even hear that "tuck" sound when phone gets locked by hard button , so that means it is booting up .
    If there had been any severe issue then how it is working ,booting up? the service center says its motherboard is gone and its Un-repairable .
    I took the phone to this service center
    29
    South Karnataka Bangalore B2X 15/8, 1st Temple Street Road, Malleshwaram, Bangalore - 560003 ( opp to asha sweets food camp ) 9632045836
    I don't want to repair my phone from local shop , please let me know what to do .
    Thanks .
    Also there is one service center
  2. ariblaze
    Jelly Bean Apr 25, 2016
  3. Jitesh Saitawadekar
    KitKat Apr 25, 2016
    Jitesh Saitawadekar , Apr 25, 2016 :
    Just switchoff & keep your phone in bowl of rice for 2 days so that it absorb all the water left inside & then try turning it on...that might help you.
  4. rahulnegi1409
    Eclair Apr 25, 2016
  5. rahulnegi1409
    Eclair Apr 25, 2016
    Its been a month or so I think , Should I put it in bowl or rice even now? ( this thing happened in holi)
  6. Eshan_Anand
    Ice Cream Sandwich Apr 25, 2016
  7. Jitesh Saitawadekar
    KitKat Apr 25, 2016
    The first thing you should always do when it gets contact with water is to wipe it with cotton towel & switch it off then keep it in a rice for at least 2 days just remember this...just for now give it a try hope it works or else i am sure you don't wanna spend 17500 for just a repair!!!:confused::confused:
  8. rahulnegi1409
    Eclair Apr 25, 2016
  9. m1tch3m
    Ice Cream Sandwich Apr 26, 2016
    m1tch3m , Apr 26, 2016 :
    What people tend to not do which you should when you try the rice trick is put the phone and rice in something sealed like a container or the rice won't be able to do its job...
  10. cedalone
    Jelly Bean Apr 26, 2016
    cedalone , Apr 26, 2016 :
    you can change the screen by yourself, cost around 100€ for a new screen on internet, i did it for mine, not easy but doable. 12493883_10153869576871738_7960558741937224176_o - copie.jpg
