Working one plus type c bullets not working for one plus
  1. stijnonlijn
    Ice Cream Sandwich Nov 6, 2018
    stijnonlijn , Nov 6, 2018 :
    So did you actually try what I said?
    #41
  2. N1540178642932
    Donut Nov 6, 2018
    #42
  3. stijnonlijn
    So you turned on OTG, fully turned the phone off, plugged the earphones in, turned on the phone again and they don't work?
    Edit: They also don't show in your media output options?
    #43
  4. N1540178642932
    Donut Nov 6, 2018
    N1540178642932 , Nov 6, 2018 :
    ya
    #44
  5. stijnonlijn
    Well then I really don't have a clue. Like I said it worked on mine and if you really tried everything we suggested then they might as well just be broken. I can't help you any further.
    #45
  6. N1540178642932
    Donut Nov 6, 2018
    ok
    #46
  7. EmanueleFulco
    Honeycomb Nov 10, 2018
    EmanueleFulco , Nov 10, 2018 :
    I want to buy them for OnePlus 5T. Is there a way to listen music without activating otg every 10 minutes?
    #47
  8. stijnonlijn
    Ice Cream Sandwich Nov 10, 2018
    stijnonlijn , Nov 10, 2018 :
    If you keep using them you don't. But please search around here. Saw some negative reviews on non-6T users. So watch those before buying them.
    Hope that helps!
    #48
  9. EmanueleFulco
    Ahh ok, so if you are listening to music they will be active for the time of listening, on the contrary if you stop listening, a timer of 10 minutes will start in order to automatically switch OFF OTG.
    Thank you very much, I think I'll buy them because the software team must solve these problems.
    #49
  10. stijnonlijn
    That's true. As it's Oneplus they can fix it haha. No but i read that some users can only listen music but not make phone calls with them. But yea quality wise they are just great!
    #50
  11. Baymax
    Starting Point Expert Community Expert Nov 10, 2018
    Baymax , Nov 10, 2018 :
    Should I get a pair and test with my 6?
    #51
  12. stijnonlijn
    Don't know. Sun90 (or was it 99 idk) tested them on his 3 and he said this:
    Got my type c today.
    Unfortunately , it will work only with USB Audio player pro app for now.
    Call functionality isn't working and no other music app is supportive apart from the one mentioned above.
    For me they worked on my 3T with Spotify but I didn't try to call with them, too lazy to change my SIM again because I tend to break them :')
    #52
  13. kriteshshah
    Froyo Nov 11, 2018
    kriteshshah , Nov 11, 2018 :
    yes I have used them on OP3T and they don't work for calls
    only media apps are working
    #53
