one plus wireless bullets Z
  1. ankykamboz
    Cupcake Dec 31, 2020
    ankykamboz , Dec 31, 2020 :
    I m using one plus wireless z from last 6 month.i had face the problem of disconnection many times. it disconnect automatically ,after that I have to wait for it to switch off which takes 2-3 weeks to drain battery after left it switch on .this time same problem but after this it is reflecting in my phone "bluetooth device available ,but it is not pairing now,it is showing"unable to communicate with one plus wireless z bullets".
    I had reset my headphone also by pressing volume key.
    I had also clear storage and cache in bluetooth .
    I m using one plus 6 .
    please guide
    _Ramji_ likes this.
  2. _Ramji_
    Donut Mar 30, 2021
  3. 007@nuj
    Cupcake May 4, 2021
  4. G_Tanmay_Gupta_stNl
    Cupcake May 7, 2021 at 7:01 PM
    G_Tanmay_Gupta_stNl , May 7, 2021 at 7:01 PM :
    Hey please try to reset you earphones. also you can discharge them completely and the charge and reset them before using. if still problem doesn't solve then replace it if its under warranty.
  5. G_Tanmay_Gupta_stNl
    Cupcake May 7, 2021 at 7:02 PM
    G_Tanmay_Gupta_stNl , May 7, 2021 at 7:02 PM :
