9
Oneplus 2 Auto rotation not working properly "ROM BUG"
  1. bala
    Gingerbread Aug 26, 2015
    bala , Aug 26, 2015 :
    I'm Using Oneplus 2 for a couple of days now and facing the weird issue of the phone not changing the orientation at times even though the Auto rotation toggle is turned on. A quick reboot just solves the issue but i wondering is it just for me or anyone also have faced this atleast once?
    NOTE : it does not occur often but it does happens at times and its really annoying as the device won't change the screen contents to landscape orientation or vice versa
    THANKS !!!
  2. amruthamba fnu
    amruthamba fnu , Aug 26, 2015 :
    IS this before the update or after?
  3. LeGaulois
    Honeycomb Aug 26, 2015
    SiggyT likes this.
  4. bala
    Gingerbread Aug 27, 2015
  5. Virtualy_Richie
    Cupcake Aug 27, 2015
  6. deejay01
    KitKat Aug 27, 2015
    deejay01 , Aug 27, 2015 :
    Mine has done that. I think it did it once yesterday. And mine is updated.
    the_reckoner likes this.
  7. bala
  8. solleks
    Honeycomb Aug 27, 2015
    solleks , Aug 27, 2015 :
    I also have this bug over and over. I don't know what triggers is but the only way to fix it is to reset it. I hope it's a software issue and not hardware like a faulty gyroscope.
  9. muntajeebali
    Honeycomb Aug 29, 2015
    muntajeebali , Aug 29, 2015 :
    Get new update
  10. kartikkumart
    Cupcake Aug 29, 2015
  11. bala
    Gingerbread Aug 31, 2015
  12. p51d007
    KitKat Aug 31, 2015
    p51d007 , Aug 31, 2015 :
    Report it...the only way Oppo/OnePlus can insure that the Oppo Find9 is competely bug free, is by those purchasing the OP2 to beta test it first.
  13. marian_1x
    Donut Aug 31, 2015
    marian_1x , Aug 31, 2015 :
    Hi, I also have this problem.
    I updated right after I got it out of the box so I can't tell if this bug was not present on the old software.
  14. tatur23
    Donut Aug 31, 2015
    tatur23 , Aug 31, 2015 :
    I have my OPT from last week and my first impressions are very good but i have 2 problems that i can't solve.
    -Double tap: It doens`t work always. If i hold the phone works better, but if is in the table i have to tap several timis until it works. Is someone having this issue? Could be a hardware problem? I have the plastic protector, i ddon't want to remove it for see if it works better without it.
    -Rotation in google maps, Rotation works perfect in general, but when i use Google navigation GPS is not rotating so i have to put it in vertical.
    If someone could help me with this problem i aprecciate it.
    cmadrone likes this.
  15. Allyn T.
    Allyn T. , Aug 31, 2015 :
    Hi there. Sorry to hear that you're having issues with your OnePlus 2, but we'd like to help. Could you please contact our support by submitting a ticket https://oneplus.net/support and please let me know of your ticket# so I may further assist you.
    Please don't forget to include a video showing the problem so that we may diagnose and resolve your issue ASAP. Thank you for your cooperation. :)
  16. n.halliyal
    Cupcake Sep 4, 2015
    n.halliyal , Sep 4, 2015 :
    Hello I have been using the OP 2 since 15 days. I have the latest oxygenOS ROM i. e 2.0.2 but still this bug is present. It has been there since i got the phone.
  17. gjaroudi
    Cupcake Sep 8, 2015
    gjaroudi , Sep 8, 2015 :
    I have the same problem of auto rotation, not always working properly.
  18. 591994
    Eclair Sep 9, 2015
    591994 , Sep 9, 2015 :
    I have the same issue , it works only after I reboot . DW it shld be a software bug , and even if it hardware ( rare ) we have warranty
  19. viralprabhu
    Donut Sep 10, 2015
    viralprabhu , Sep 10, 2015 :
    Hi, I am using OnePlus 2 with Oxygen version 2.0.2. I am currently facing issue with Auto-Rotation specifically with Google Maps app (v9.14.0). The orientation doesn't seem to change to landscape automatically even when you tilt the phone. Initially, I thought this might be an issue with my phone. But soon realized that all the other apps work absolutely fine and rotate automatically to landscape orientation when tilted. Is anyone else facing this issue with Google Maps app on your OP2? Is there any support available to fix this issue?
  20. mkernbach
    KitKat Sep 10, 2015
    mkernbach , Sep 10, 2015 :
    There is the same with Waze (another navigation soft)
