Oneplus 2 Battery scam?
  1. dsmonteiro
    Community Consultant Staff Member Apr 23, 2018
    dsmonteiro , Apr 23, 2018 :
    You said filled with fishy stuff. What fishy stuff?
  2. Auxilus
    Cupcake Apr 23, 2018
  3. dsmonteiro
    OnePlus did not collect private user data. It did collect usage statistics and other related data. Sure, it did in a somewhat invasive way, but no private user data was collected. Also, bear in mind that (unfortunately) this is a common industry practice.
  4. Auxilus
  5. MarcioReis87
    Ice Cream Sandwich Apr 23, 2018
  6. anupritaisno1
    KitKat Apr 24, 2018
    anupritaisno1 , Apr 24, 2018 :
    Just so you know apps are not allowed to access hardware information. They can sometumsoget around this because the sysfs selinux policy sometimes can be a little relaxed but 90% of the time merely having selinux in enforcing will prevent apps from accessing hardware statistics
    The second issue, even if selinux were to be permissve android is designed to distrust every app not made by your manufacturer. Unless the application carries the platform signature access will still be very restricted, if even access to the actual hardware statistics is possible
    You're using software that is calculating battery capacity based on a heuristic. It doesn't work that way
  7. anupritaisno1
    KitKat Apr 24, 2018
    You can get NFC with a SIM card module
    If you actually do find a SIM card module you'll have to message me I'll build a ROM with NFC HALs compiled for you
