OnePlus 2 Problem.
  1. AnOnAnTu
    Cupcake Jun 4, 2019
    AnOnAnTu , Jun 4, 2019 :
    I am using OP2 last 2.5 year. I generally face two problems.
    1. When I turn on Flight mode, then automatically Bluetooth turns on.
    2. I like to keep my display back light time 10 mins. But after sometimes autocratically it gone to 10 second!
    What should I need to do?
    S VIMAL likes this.
  2. meatandy
    Oreo Jun 4, 2019
    B_Wrath likes this.
  3. Rusty NZ
    Marshmallow Jun 4, 2019
    meatandy likes this.
  4. pablofg1978
    Spanish POC Assistant Head Moderator Jun 4, 2019
    pablofg1978 , Jun 4, 2019 :
    There are no more updates for the Op2, so the only option is to install a custom rom
  5. meatandy
    Oreo Jun 4, 2019
    meatandy , Jun 4, 2019 :
    I was talking about your flight mood .:cool::D
  6. Rusty NZ
    Marshmallow Jun 5, 2019
    Rusty NZ , Jun 5, 2019 :
    The original poster didn't ask for an update. Do you think installing a custom rom is a little extreme to fix those problems? I would hope the worst case scenario would be to do a factory reset.
  7. Rusty NZ
    I think you mean Flight mode. Don't try to confuse people.
  8. pablofg1978
    Spanish POC Assistant Head Moderator Jun 5, 2019
    pablofg1978 , Jun 5, 2019 :
    I don't think that using a rom that has not been updated from the last two years is good for use. From security updates, bug fixes and features I would install a custom rom (like I did it for my opo).
    That is my personal recommendation
  9. C1559288851385
    Cupcake Jul 9, 2019
  10. D1563003441460
    Cupcake Jul 13, 2019
  11. E1539419244482
    Cupcake Aug 18, 2019
    E1539419244482 , Aug 18, 2019 :
    Bhai update nahi ho raha
  12. pablofg1978
    Spanish POC Assistant Head Moderator Aug 18, 2019
    pablofg1978 , Aug 18, 2019 :
    This thread is in English, please respect it
  13. #13
