582
OnePlus 2 regional versions explained
  1. Kvarunt
    Cupcake Aug 16, 2015
    Kvarunt , Aug 16, 2015 :
  2. Denco1
    Gingerbread Aug 17, 2015
    Denco1 , Aug 17, 2015 :
    I have.
  3. techygeek
    Ice Cream Sandwich Aug 17, 2015
  4. abraxas77
    Honeycomb Aug 17, 2015
  5. iomollie
    iomollie , Aug 17, 2015 :
    They are the same?
  6. santyblair89
    Cupcake Aug 17, 2015
    santyblair89 , Aug 17, 2015 :
    id love to know if anyone ever manages to flash the Chinese versions Modem Radio to get LTE in NA
  7. honeyerh
  8. Papao
    KitKat Aug 17, 2015
    Papao , Aug 17, 2015 :
    For a better understanding, check out on Wikipedia, you may find your country there:
    https://en.wikipedia.org/wiki/List_of_LTE_networks
    gabriel.dumitru likes this.
  9. toroscan
    toroscan , Aug 17, 2015 :
    When you look at cellphone usage on a worldwide basis, some compromises have to be made. With some exceptions, pretty much only the USA still uses CDMA. It takes an entirely different cellphone to use CDMA. Completely different electronics. It is not the way the world at large is going. The USA still uses miles and inches. What can I say?
  10. Texan21
    Texan21 , Aug 17, 2015 :
    This is extremely helpful. This was one concern I had about getting this device or any device from overseas. Glad you cleared this up and I look forward to getting an invite soon.
  11. ferties04
    Froyo Aug 17, 2015
    Westernise likes this.
  12. gonger
    gonger , Aug 17, 2015 :
    Hi all,
    Not sure if anyone asked this already so apologies in advance if that has happened.
    If I am going to an OPO store in China would I be able to buy an EU version of the phone if I ask for it specifically?
    Thank you all for the help and for maintaining such a great community!
  13. rudra mitra
    Eclair Aug 17, 2015
  14. douglasleer
    Froyo Aug 17, 2015
    douglasleer , Aug 17, 2015 :
    You should have learned enough stuff after Oneplus One.
    What's the point of explaining these to your users?
  15. sykez
    sykez , Aug 17, 2015 :
    But according to the screenshot, is it not both working at the same time? :/
  16. prabhu.v143
  17. NETSAP
    Eclair Aug 17, 2015
    NETSAP , Aug 17, 2015 :
    Good Info
  18. chuengdzinyung
    Eclair Aug 17, 2015
  19. Denco1
    It is Dual Sim Dual Standby so can receive calls/texts from both at anytime but once you are in a call from one sim you cannot receive calls/texts from the other sim.
  20. bubu83
    bubu83 , Aug 17, 2015 :
    Yes. so it seems.
