300
OnePlus 2 Rumors - We are mad.
  1. Dr. Indest
    Lollipop Jun 18, 2015
    #41
    Wadesauce, 2+2=5, mrsim and 6 others like this.
  2. Rutha Mae
    Cupcake Jun 18, 2015
  3. DaxNagtegaal
    Marshmallow Jun 18, 2015
    DaxNagtegaal , Jun 18, 2015 :
    Because the 810 will run at a low clockspeed to prevent overheating which means it won't be very powerful. Look up some 810 vs 808 or 805 stuff on Google, you'll see.
    #43
    sholiday, okay_bye, dhaugru and 3 others like this.
  4. Hassan_Abdul
    KitKat Jun 18, 2015
    Hassan_Abdul , Jun 18, 2015 :
    I will simply wait and see and decide if to buy when it is ready
    Have been quite satisfied with the ONE and if the TWO would be as good compared to it's competitors as the ONE has been last year I am sure to buy it
    In the meantime I will wait until it is ready and available. ..
    I think Oneplus will surprise us again
    #44
    d3gn likes this.
  5. t4ww4b
    Jelly Bean Jun 18, 2015
    t4ww4b , Jun 18, 2015 :
    I actually don't see the point of underclocking by 700mhz (as its theoretical maximum speed is 2.5GHz). You guys should've chosen the 808. It's cheaper and it works out of the box. If you don't want to settle then the 820 was a better choice. There will always be devices that will throttle with this SOC and you guys will have to provide those users a fix every time (just like the touchscreen isues).
    #45
    silvagroup, okay_bye, dhaugru and 8 others like this.
  6. d3gn
    Donut Jun 18, 2015
    #46
  7. Dr. Indest
    Dr. Indest , Jun 18, 2015 :
    I could not agree more.
    #47
    okay_bye, AsadP, mrsim and 8 others like this.
  8. abhishek.sharma
    Honeycomb Jun 18, 2015
    abhishek.sharma , Jun 18, 2015 :
    But if 808 or 805 works at full speed, don't you think it will be overheated.?
    #48
  9. Hassan_Abdul
    KitKat Jun 18, 2015
    #49
  10. nash859
    #50
  11. DaxNagtegaal
    No it doesn't because they're quad cores and the 810 is an 8 core. It's too much for such a little space.
    #51
  12. Dr. Indest
    Also, our "rumors" kept claiming that in order to prevent the overheating, you would have to undervolted the chip. Based on your post, it does not sound like a rumor.
    #52
    okay_bye likes this.
  13. jandekkers126
    Ice Cream Sandwich Jun 18, 2015
    #53
    thudrumble likes this.
  14. leopardo
    Froyo Jun 18, 2015
    leopardo , Jun 18, 2015 :
    I am ready for the drama.
    810 > 808 cos during the winter days your fingers will have a warm resting place.
    #54
  15. t4ww4b
    The 808 has 6 cores thought.
    #55
  16. LostPorcupine
    KitKat Jun 18, 2015
    LostPorcupine , Jun 18, 2015 :
    They've all been tested pretty well at this point. There is some kind of flaw in the 810 (regardless of rumors, this that. It did exist, may or may not, blah) that causes extreme heat at it's base frequencies. After a few minutes running full on, it throttles so heavily that it underperforms everything severely. The 808 is slower, but it runs at that speed stable without flaw. It's only slower for the first few minutes, and then when the 810 throttles, the 808 shines.
    #56
    sholiday, dhaugru, Takendown and 4 others like this.
  17. Ivanpoocky13
    KitKat Jun 18, 2015
    Ivanpoocky13 , Jun 18, 2015 :
    Glad to see your clarifying the situation here.
    #57
  18. LostPorcupine
    KitKat Jun 18, 2015
    Myself, as long as the new OP2 has the following met, I'll consider it if no performance or heating issues come.
    1. HDMI out. No question. My next phone (in the next few months) will have this.
    2. No bigger than current dimensions. 5.2" or so would be perfect, 5.5" is alright as long as the bezels stay the same.
    3. Battery life; my OPO after some tweaking is "good enough", but it really does need to be a bit better.
    #58
  19. Tr1p
    Gingerbread Jun 18, 2015
    Tr1p , Jun 18, 2015 :
    I'm sure there will be other problems come up just like the one , a good cpu doesn't fix the rest of the white compartments ;-)
    #59
  20. Tamashi
    Tamashi , Jun 18, 2015 :
    I'd prefer the first version of 810. I badly want a mobile stove, to take with me where ever I go. Which is not far! I'mad mad that you're mad about this. :(
    #60
