2
OnePlus 3 automatically going to silent mode
  1. matt13rox
    Donut Dec 8, 2017
    matt13rox , Dec 8, 2017 :
    All of the activity launcher apps seem to crash on Oxygen OS. So if you install Nova launcher, and add the widget called activities it'll do fine. Within activities widget, look for Settings > Automatic Rules and place it somewhere on your home screen. Then launch the widget and add rules or delete em.
  2. PAPZI1957
    Gingerbread Dec 8, 2017
    PAPZI1957 , Dec 8, 2017 :
    You do not have to use Nova launcher. It's enough if you install it, then there will be a Nova Actions widget between the widgets, and the second option for automatic rules must be selected in these settings.
  3. PAPZI1957
    Unfortunately...
  4. Onatashi
    Cupcake Dec 8, 2017
    Onatashi , Dec 8, 2017 :
    Hi all,
    I too have the same issue, I have Nova launcher installed and gave this a shot... just testing it now.
  5. Onatashi
    Cupcake Dec 8, 2017
  6. Onatashi
    Cupcake Dec 8, 2017
    Use Nova launcher to delete the rule and it will fix the problem
  7. krv09
    krv09 , Dec 8, 2017 :
    Try factory reset and install the apps manually without using automatic restore, it might help
  8. MyronvVelsen
    Cupcake Dec 21, 2017
    MyronvVelsen , Dec 21, 2017 :
    Where do i find the settings to disable this rule?
  9. broodrooster
    Gingerbread Apr 6, 2018
