Oneplus 3 Camera issue
  1. Vinayak Malode
    Eclair Jul 11, 2017
  2. mkharbanda
    Honeycomb Jul 11, 2017
    mkharbanda , Jul 11, 2017 :
    It tends to get hot when you are using it too much with Flash On. Normal usage shouldn't be an issue. How long you use it and gets hot?
  3. Heisenberg_009
    Ice Cream Sandwich Jul 11, 2017
    Heisenberg_009 , Jul 11, 2017 :
    Heat is a relative thing. And continuous camera usage will heat up your phone. Especially if HDR is active quite a lot or you use manual mode often
  4. Vinayak Malode
    Eclair Jul 11, 2017
    Vinayak Malode , Jul 11, 2017 :
    No I'm not that much of camera user just I try to take a 2 or 3 photos with normal mode it's getting hot...
  5. G_plusone
    Marshmallow Jul 11, 2017
  6. HIT-199
    HIT-199 , Jul 11, 2017 :
    Try the "open camera" app - there Software has special settings for oneplus phones, maybe the app can handle better with the battery
  7. Vinayak Malode
    Eclair Jul 11, 2017
    Both side shooting with Only photos....
  8. Punk_69
    Lollipop Jul 11, 2017
    Punk_69 , Jul 11, 2017 :
    special settings, like ?? (I'm quite curious about it)
  9. HIT-199
    Okay "special settings" sounds wired after reading it again ^^` I mean there Software are kind of optimized/ tweaked for oneplus phones - and other phones maybe too but I just know this for OP - and when there are any issues there tend to fix them way faster then OP can.
    Punk_69 likes this.
  10. G_plusone
    G_plusone , Jul 11, 2017 :
    How long do you use it for the device to heat
  11. Vinayak Malode
    Eclair Jul 11, 2017
  12. G_plusone
    So your becomes hot before you can take some 2 to 3 pictures
  13. Vinayak Malode
    Eclair Jul 11, 2017
  14. Anger31
    Donut Jul 11, 2017
  15. Anger31
    Donut Jul 11, 2017
    Anger31 , Jul 11, 2017 :
    Just spam so i maybe one daysomeone who is responsible For this peice of st!nking crap knows so!
  16. Anger31
    Donut Jul 11, 2017
  17. Anger31
    Donut Jul 11, 2017
    Cam works okay.. but Ego cares For cams? Facebook Instagram Girls s yes but Its a ******* device to Go on the Internet and Play Games.
  18. pgsk97
