Sound oneplus 3 Equalizer issue
  1. Kavin_bala
    Cupcake Dec 10, 2016
    Kavin_bala , Dec 10, 2016 :
    Hello guys,
    I have been facing a problem with Equalizer in one plus 3. Bass boost in Equalizer getting flat every time when I unplug the earphone and closing the play app. When I re insert and open the app I will be able to see that bass boost got reset to default. any one facing this issue?
    ROKUPOKU likes this.
  2. philippone
    Donut Jan 3, 2017
    philippone , Jan 3, 2017 :
    I can confirm this issue but now i upgraded to nougat and there is no bass boost anymore...
  3. iliazark
    Donut Jan 7, 2017
    iliazark , Jan 7, 2017 :
    On android 7 you should be able to tweak the eq from the settings... I have been facing problems though.
  4. dipeshbagul
    Cupcake Jan 20, 2017
    dipeshbagul , Jan 20, 2017 :
    I am also facing the same issue but I realised that the bass boost goes flat if earphones plugged out.
    Also facing another unusual issue related to equilizer, the equilizer setting are not working after some time or after changing the song on external online songs app like gaana.
    When I again open equilizer to check, the difference is observed.
    This was working very well in my old device. Did anyone face this, is there any solution to this?
