Oneplus 3 (o2-uk) - LTE/H/E issue.
  1. Ballistix
    Gingerbread Jul 20, 2016
    malidan likes this.
  2. remedy
    KitKat Jul 20, 2016
  3. youngr
    Cupcake Jul 21, 2016
    youngr , Jul 21, 2016 :
    having similar issues with BT Mobile. No Mobile Data connections at all. APN all in place.
  4. remedy
    KitKat Jul 21, 2016
    remedy , Jul 21, 2016 :
    Try Spell's suggestion.
  5. wii747
    Eclair Aug 5, 2016
    wii747 , Aug 5, 2016 :
    I am on BT mobile and have no issue with 4G
    remedy likes this.
  6. charleyb1993
    Cupcake Aug 12, 2016
    charleyb1993 , Aug 12, 2016 :
    Having the same issue since I recently switched from EE to o2. For me it just stays on H and won't change. I've googled and tried every possible "fix" (including the ones in this thread) but it either stays the same or gets worse. I need to find out which model I got (to see if I actually have a European model of the OP3 for it to support band 20).
    Quite annoying. I've had the phone since launch and I hope RMA is a possibility.
  7. ritchiedrama
    Ice Cream Sandwich Aug 13, 2016
    ritchiedrama , Aug 13, 2016 :
    Mine has started doing it again for the last week.
  8. charleyb1993
    Cupcake Aug 14, 2016
    charleyb1993 , Aug 14, 2016 :
    What firmware version are you on? I've seen some people having issues with LTE on the latest 3.2.4 release.
  9. ritchiedrama
    Ice Cream Sandwich Aug 14, 2016
    ritchiedrama , Aug 14, 2016 :
    Same on all, I'm using 3.2.1 and same on custom rom's etc.
  10. G_Craig_Russell_qAiq
    Cupcake Aug 20, 2016
    G_Craig_Russell_qAiq , Aug 20, 2016 :
    Same problem here. Please fix.
    My quick fix is to turn on and off airplane mode, but that obviously isn't sustainable.
    Craig
  11. remedy
    KitKat Aug 25, 2016
    remedy , Aug 25, 2016 :
    Try to flash the ROM.
  12. Karan88
    Cupcake Sep 12, 2016
    Karan88 , Sep 12, 2016 :
    I'm GiffGaff and o2 on dual SIM configuration.
    I'm having the same issue, I can no longer get LTE. I only get 4G.
    LTE used to work but suddenly stopped.
    I live in London, I went to Oslo same problem there, I went to Manchester and same problem.
    Only connects to 4G and not LTE anymore.
    I'm using the UK/EU version of the phone with Android 6.0.1, Oxygen OS 3.2.4, Build: ONEPLUS A3003_16_160806
  13. PedroAkura
  14. Karan88
    Cupcake Sep 14, 2016
    Karan88 , Sep 14, 2016 :
    Yup also tried in Stockholm now.
    Is there a fix for this?
  15. Karan88
    Cupcake Sep 16, 2016
    Karan88 , Sep 16, 2016 :
    Is there a fix or a guide to roll back on the update, to a version with LTE?
  16. budnull
    Eclair Sep 21, 2016
    budnull , Sep 21, 2016 :
    Yes i have a italian provider TIM and i get the same issue.....
