OnePlus 3 Screen Protector
  1. senthil007
    Gingerbread Jun 15, 2016
    senthil007 , Jun 15, 2016 :
    Hi I just ordered my Oneplus 3 from Amazon.in. In the description it was mentioned the phone is having a pre-applied screen protector, so does it mean that no need of going for any third party screen protector?
    The doubt arised to me because in amazon.in oneplus is also selling a screen protector for oneplus 3
  2. Dachaitanya
    Cupcake Jun 15, 2016
  3. rayth77
    Froyo Jun 15, 2016
    rayth77 , Jun 15, 2016 :
    The OP3 has a pre-applied screen protector same as all Oneplus devices, this however is not a glass screen protector but a normal one, i will use this pre-applied one until i receive the Tempered Glass Screen Protector that i ordered from China, as i have ordered 5 of them for 10€ which is alot cheaper then 12,95€ a piece for the official Oneplus Tempered Glass.
    senthil007 likes this.
  4. senthil007
    thanks for the reply.
    So if i want to put a tempered glass screen protector do i need to remove this pre-applied screen protector? or simply i can put it on top of that...
  5. OberstHeftig
    Froyo Jun 15, 2016
  6. rayth77
    Froyo Jun 15, 2016
    It is better to remove the pre-applied one before putting on a Tempered Glass screen protector. I would not recommend applying it on top of the pre-applied one.
  7. senthil007
  8. spooke
    Honeycomb Jun 15, 2016
    spooke , Jun 15, 2016 :
    Such a shame OnePlus went for a curved display, I won't be using a screen protector as they don't cover the whole screen! Why didn't they just make it flat and use the tempered screen protector to make it looked curved, like the OP2.
  9. m.e.r.
    m.e.r. , Jun 15, 2016 :
    I won't go for a tempered glass screen protector as I never broke a glass screen protector on my op1 or op2. I seem to never drop my phone. And this time we got 2.5D glass so a glass screen protector wont curve like the glass beneath it. A glass screen protector is not going to be as big as the screen. Just won't feel good to put one on
