OnePlus 3 VoLTE on T-Mobile
  1. pauld
    Froyo Aug 4, 2016
    pauld , Aug 4, 2016 :
    Actually it came turned on...I'm all for enhancements, but when they work.
    Thank you for the assist!
    #41
  2. dwlimf
    Froyo Aug 4, 2016
    dwlimf , Aug 4, 2016 :
    Unbelievable I have been dealing with people not being able to hear me for weeks now actually over a month.
    And I see countless post about VoLTE can't hear me, and even mic issues, bluetooth, and I have been working with OP tech support sending them logs.
    So going Crazy here and the fix for all these problems was so simple.
    Just go here http://downloads.oneplus.net/oneplus-3/oneplus_3_oxygenos_3.2.2/
    and follow the instruction to sideload and alakazam all your problems are gone.
    Yup seems the OTA update somehow corrupts something and sideloading the whole ROM solves the problem 100%
    I really hope this helps all of you with these issues.
    You will now have crystal clear calls on T-Mobile VoLTE.
    #42
    remedy likes this.
  3. dobiegillis
    Ice Cream Sandwich Aug 4, 2016
    #43
  4. dwlimf
    Froyo Aug 4, 2016
    Yes fixed it 100% if you are having any issues do it you don't lose your data and it works.
    #44
  5. dwlimf
    Froyo Aug 4, 2016
    Did you sideloaded from you PC the full ROM that is the 1.3GB file not the patch???
    So far sideloading the full ROM has solved the VoLTE issue for 3 of my friends so has real good results for solving the issue so far.
    If you really did do the sideload try clearing the system cache.
    #45
  6. Deactivated User
    Aug 4, 2016
    #46
