22
Network/Connectivity oneplus 3 wifi is very sensitive and keeps disconnecting.
  1. Saba2210
    Cupcake Jul 19, 2016
    Saba2210 , Jul 19, 2016 :
    Do u think it's an software problem. There's some issue with hardware. As even before updating to 3.2.1 i had same issues
    #41
  2. dindoliya
    Froyo Jul 19, 2016
    dindoliya , Jul 19, 2016 :
    I hope you have better luck than I've had. For me the problem persists with 2.4 as well as 5 GHz bands.
    #42
  3. sahirhussain
    Honeycomb Jul 20, 2016
    sahirhussain , Jul 20, 2016 :
    if its a hardware problem then i am glad that i am a lawyer.
    #43
    Saba2210 likes this.
  4. hadighattas
    hadighattas , Jul 20, 2016 :
    Probably a software problem that was in the software from starting as the op3 use similar parts to all other phones in the market.
    #44
  5. J12894
    Gingerbread Jul 20, 2016
    J12894 , Jul 20, 2016 :
    Also feeling the same problem recently.
    My router has 2 signal, 1 2.4GHz and 1 5GHz
    When I am at in a further room from the one I put my router, even the Wifi signal is around 3/5 - 4/5 ,it will just abandon the wifi and switch to mobile data and immediately connect to another signal when there is any dip in the signal strength.
    As it keep disconnect and switching from difference wifi signal and mobile data, it disconnect any continuous download. Long website will just cannot load the bottom part, Youtube videos will stuck at buffering, Facebook timeline will be cut.
    Please someone from OnePlus team try to fix this. As this has never happened on my OPO and other devices like Nexus 4 or Nexus 7
    #45
  6. Fenru
    Donut Jul 20, 2016
    Fenru , Jul 20, 2016 :
    I think you guys should try ryanjf's advice from the previous page (adb sideload from computer via usb). Use the 3.2.1 files from the official downloads page and see how it goes. There's a chance the 3.2.1 OTA could have corrupted during the download.
    #46
  7. movisman
    Donut Jul 20, 2016
    #47
  8. Hasimir
    Cupcake Jul 20, 2016
    #48
  9. bauerjoe
    bauerjoe , Jul 20, 2016 :
    I had the same problem. At the moment it seams to be fixed after I switched on the old DCHP client implementation in the developer settings (in the network section).
    #49
  10. sahirhussain
    then this explains OP3 having problem on all wifi connections for me but how come some people have it and others dont? it seems that OP3 doesnt like automatic ipv4-ipv6 switching either. ill try your workaround and see if it helps me.
    #50
  11. movisman
    Donut Jul 20, 2016
    movisman , Jul 20, 2016 :
    I tried this already, and it didn't seem to make a difference to the poor speed/signal from the OP3. I will try it again though to see if it helps with the random disconnections, I seem to remember I had the same behaviour either way.
    #51
  12. J12894
    Gingerbread Jul 21, 2016
    J12894 , Jul 21, 2016 :
    Reporting with no luck too. After the switching, still disconnect at the same spot in my home
    #52
  13. G_Paul_Valakelis_PJdu
    Eclair Jul 21, 2016
    G_Paul_Valakelis_PJdu , Jul 21, 2016 :
    I'm having no issues with WiFi. In fact, this is the best wifi performing phone I've had. I get better wifi than my girlfriends iPhone 6s.
    I have Verizon Fios 50 up and 50 down and it's flying. Before this I had an LG G3 and an amazon Fire Phone rooted with CM. Both sucked.
    The screenshot is from me standing in my bathroom on the upper level of my place, at least 3 rooms away and separated from the router by a full level.
    #53
  14. F_Marko_Rodic_mrpj
    Cupcake Jul 21, 2016
    F_Marko_Rodic_mrpj , Jul 21, 2016 :
    So there are a lot of bugs here: wifi disc., bad video audio, voip audio, etc. Hope for somebody in 1+ testing this device before production. I am willing to buy, but only after solving this issues
    #54
  15. J12894
    Have you tried using Wifi at there for a long period of time? Like streaming a movie or playing online games or scrolling though facebook timeline for an hour or so.
    Since I don't have speed issue but it just disconnect and reconnect the network when I am in my bathroom (3 walls away from my router, 3/5 to 4/5 signal strength). The issue happen quite randomly when the signal is dip a little, it drop the wifi connection and immediate connect to another one.
    #55
  16. Pdajah
    Ice Cream Sandwich Jul 21, 2016
    Pdajah , Jul 21, 2016 :
    Now tested my oneplus 3 on 3 different routers and no issues with WiFi.
    #56
  17. bafranksbro
    bafranksbro , Jul 21, 2016 :
    The issue I'm having is the wifi disconnecting when the screen is off, it keeps doing it and will reconnect when I unlock the screen. I have the power settings set correctly and yet it's acting like I have some sort of power save thing on.
    #57
  18. G_Paul_Valakelis_PJdu
    Eclair Jul 21, 2016
    Yup. I've been at home all day and it's fine. No issues.
    But my dash charge doesn't work lol
    #58
  19. espinozaja
    Eclair Jul 23, 2016
    espinozaja , Jul 23, 2016 :
    I didn't have this issue when I first received my Oneplus 3. I went and updated to the latest os update, and now I notice that the wifi toggles on and off repeatedly. I've tried to reset the wifi pairing, but that did not solve it. Anyone have a solution?
    #59
  20. espinozaja
    Eclair Jul 23, 2016
    I've noticed that this is intermittent. It will toggle on and off for a while then it stops on it's own... I'm running on 2.4 wifi with no bluetooth devices currently. I've checked the channels and no one else is on my channel. Also all my other devices (non-android) are working fine on the wireless. Does anyone have a recommendation for an all around wifi/bluetooth analyzer?
    #60
