OnePlus 3 won't turn on
  1. RandomDude66613
    Gingerbread Apr 14, 2017
    RandomDude66613 , Apr 14, 2017 :
    After I woke up I grabbed my OnePlus and start browsing Facebook and other news... After I'm done I goes to Paly Store to check if I have any updates for the app's, there was couple of them, but I can't download and install them, I got error "error retrieving information from server" so I clean the cache of Play Store and Google Play Services, that won't help, so I decided to reboot my phone. I pressed power button and select reboot. The phone goes off and now I can't turn it back on, holding the power button doesn't do anything, also the led doesn't do anything when I'm connecting the charging cable.
  2. RandomDude66613
  3. hazat19
    Cupcake Apr 14, 2017
    hazat19 , Apr 14, 2017 :
    from experience with my 1 plus 2 having the rare problem like your 1 plus I have fixed it from just spamming the power button and the volume buttons and it could work I hope my suggestion works
  4. No. 07428
    Jelly Bean Apr 14, 2017
    No. 07428 , Apr 14, 2017 :
    Try holding the power button for much longer than usual. For a minute or longer.
    Loveit and elanglois like this.
  5. elanglois
    Lollipop Apr 14, 2017
    elanglois , Apr 14, 2017 :
    Ive seen the same. Give it about 10 minutes and then hold down the power button forever! Every time I panick and think its dead, it eventually came back on.
    _DEDSEC_ and Salt505 like this.
  6. RandomDude66613
    I did for like 3 mins, and different combinations of volume up, down and power button
  7. No. 07428
    Yes indeed. ^
  8. elanglois
  9. No. 07428
    elanglois likes this.
  10. RandomDude66613
    Gingerbread Apr 15, 2017
    RandomDude66613 , Apr 15, 2017 :
    I've been holding the power button for like 20 mins already. Nothing happened
  11. No. 07428
    Jelly Bean Apr 15, 2017
    No. 07428 , Apr 15, 2017 :
    What happens when you plug your phone in?
  12. RandomDude66613
    Absolutely nothing, no led signal, no vibration, nothing...
  13. RandomDude66613
  14. Owoturo Oluwatimi
    Froyo Apr 15, 2017
    Owoturo Oluwatimi , Apr 15, 2017 :
    Was your phone rooted? I had this issue a while back and it was because of an error called dm-verity. What happened was my phone looked like it wasn't on but it was indeed on. For some reason after some key combinations and continuous pressing I was able to see the error show up on boot. I eventually flashed stock recovery again and the error was gone. I hope this helps
  15. Owoturo Oluwatimi
    Froyo Apr 15, 2017
    My advice is to flash stock recovery again by using ADB on a PC. That should bring the device back to life because I feel it is actually on as in my own case
  16. RandomDude66613
    Yes have root, unlocked bootloader and I have TWRP recovery.
  17. Owoturo Oluwatimi
    Froyo Apr 15, 2017
    That's why. Your Phone is on, it's not off. Flash stock recovery and Flash the latest Oxygen os.
  18. RandomDude66613
    Nothing happened when I'm connecting the phone to the PC
  19. RandomDude66613
    Ok so I tried to play with different combinations of holding power button and volume buttons and now my PC give me some kind of sound when I'm connecting and disconnecting the phone to the PC.
  20. Owoturo Oluwatimi
    Froyo Apr 15, 2017
    Yeah that proves the device is on. make sure you have the correct ADB drivers
