OnePlus 3 won't turn on
  1. RandomDude66613
    Gingerbread Apr 15, 2017
    RandomDude66613 , Apr 15, 2017 :
    I do have ADB drivers installed. Also I have OnePlus 3 driver instaled with OnePlus 3 ToolKit.
  2. RandomDude66613
    So what I have to do now?
  3. Owoturo Oluwatimi
    Froyo Apr 15, 2017
    Owoturo Oluwatimi , Apr 15, 2017 :
    What's happening is your device keeps restarting which was my own case. I did find a way to boot it into fastboot though and that's what you need to do in order to be able to start any flashing or repairs
  4. RandomDude66613
    Well I'm my case it's looks like it's on all the time, and ADB does not see my device connected
  5. elanglois
    Lollipop Apr 15, 2017
    elanglois , Apr 15, 2017 :
    does fastboot see it? and what does the PC see?
    and BTW, its not DM verity as that just gives a warning. Although maybe its more than a warning if you decrypt ? I'm still encrypted.
    Looking at what the PC sees will tell us what is happening.
  6. RandomDude66613
    The PC just give me the sound like I connect a usb stick, and when I type ADB devices, it says no devices found
  7. SivaMaxwell
    SivaMaxwell , Apr 15, 2017 :
    Stop doing anything for a while.
    I too lost lot of time in this error.
    First, just leave the phone for while. DOnot press, do nothing. But watch
    Next, whenever it comes to life, in the bootinng warning, boot into boot loader. If it doesn't come to life automatically, long hold the power key for 40 seconds, and when the bootloader warning comes, boot to bootloader.
    It needs some patience.
  8. RandomDude66613
    This is what my PC showing me
  9. RandomDude66613
  10. robogo
    Honeycomb Apr 15, 2017
    robogo , Apr 15, 2017 :
    Use the mega unbrick guide, all the info you need is there.
    Your PC is recognizing your phone, which means it still works.
    RandomDude66613 likes this.
  11. Khyamik
    Cupcake Apr 15, 2017
  12. RandomDude66613
    Thx, my OnePlus showing me that the battery is low so I'll put it on charge for a while and will see if I can boot it up.
  13. RandomDude66613
    Now I've got this, pressing power button and volume up or down doesn't do much.
    If I hold power and volume down I just have a white led.
  14. RandomDude66613
  15. robogo
    See, it turned on.
    Now go through the unbrick guide one step at a time.
  16. RandomDude66613
    Gingerbread Apr 16, 2017
