Oneplus 3T 128GB uneven display
Oneplus 3T 128Gb uneven display
  1. Yes
    3 vote(s)
    100.0%
  2. No
    0 vote(s)
    0.0%
  1. ramneekgarg
    Gingerbread Dec 27, 2016
    ramneekgarg , Dec 27, 2016 :
    Me and my friend ordered oneplus 3t last week and we got it yesterday but in both handsets theres issue with screen on white color. My friends 3t have lower portion of screen less bright while mine having upper portion of screen less bright it gives a liitle yellowish tint where its less bright. that looks really weirdie. Any one else having same issue? or all Amoled panels are like this.
    Devghost likes this.
  2. ramneekgarg
    Gingerbread Dec 28, 2016
    ramneekgarg , Dec 28, 2016 :
    Anyone having similar issue
  3. Manas Saha
    Honeycomb Dec 29, 2016
    Manas Saha , Dec 29, 2016 :
    I have the 64Gb Op3T. I can notice a very slight purple tint towards the right and left edges compared to the center of the screen.
    This is only noticeable if you have a 100% white photo. If you search in google images with "white color" then you will get some of these images. just download it and view it full screen.
    Also I have seen that this issue vanishes if the screen brightness is more than 1/3rd of the slider. So its noticeable only if the room is very dark and the screen brightness is very low.
    There are couple of LCD test images here.
    http://www.lagom.nl/lcd-test/contrast.php
    I think the OP3T display is not bad. However, it fails miserably in the "Clock and phase" and "Black Level" test image in the above link.
    ramneekgarg likes this.
  4. ramneekgarg
    Gingerbread Dec 30, 2016
    ramneekgarg , Dec 30, 2016 :
    My phone's half panel have yellow tint as i mentioned above not just corners and thats looks very bad. Even on full brightness i can see that with pure white image having text
  5. maawiiie
    Cupcake Jan 7, 2017
    maawiiie , Jan 7, 2017 :
    I've got the same problem, it's pretty annoying!
  6. ramneekgarg
    Gingerbread Jan 7, 2017
    ramneekgarg , Jan 7, 2017 :
    When u bought it
  7. maawiiie
    Cupcake Jan 8, 2017
  8. ramneekgarg
    Gingerbread Jan 9, 2017
  9. amanenig
    Cupcake Jan 9, 2017
  10. sandesh9101
    Cupcake Jan 10, 2017
    sandesh9101 , Jan 10, 2017 :
    Even me & my brothers one plus two shows difference in display brightness.... His phones display is yellowish
  11. maawiiie
    Cupcake Jan 11, 2017
    maawiiie , Jan 11, 2017 :
    mine looks yellowish from the top of the display
  12. ramneekgarg
    Gingerbread Jan 18, 2017
    ramneekgarg , Jan 18, 2017 :
    Mine was also same...
  13. uttam_kr
    Cupcake Jan 20, 2017
