Battery/Charging Oneplus 3T charging problem
  1. playhardk
    Cupcake Dec 23, 2016
    playhardk , Dec 23, 2016 :
    Just got my phone. It seems when connecting the cable to the phone can use either side of the cable(unlike my Samsung S3 can use only one side, can't plug in if upside down). Is this true? Sometimes I have to unplug and plug 2 or 3 times to be able to get the phone to charging. Anyone has this problem? I am worried because this problem is the exact same problem that I have with my Samsung S3, very difficult to get it to charge!
  2. playhardk
    And sometimes, it is charging but it is not dash charging. The connection is not stable! Need to unplug and plug a few times to get to dash charging. Anyone has this problem?
  3. andres lv
    Cupcake Dec 24, 2016
  4. DJDavid98
    Donut Dec 24, 2016
  5. j244
    Ice Cream Sandwich Dec 24, 2016
    j244 , Dec 24, 2016 :
    1: Yes there is no up or down, right or wrong.
    2: No I never had this, mine always charges.
    3: For Dash charging to happen you must check if the cable is firmly attached to the charger block, if it's a little bit loose it will charge by not with Dash.
    playhardk likes this.
