[OnePlus 3T] Unknown files accumulated 17GB in 'OTHERS'
  1. patrickcrayon
    Cupcake Feb 20, 2018
    patrickcrayon , Feb 20, 2018 :
    Hi OnePlus 3T community, good day!
    I have noticed that my storage got 17GB of unknown files which I'm unable to find for me to delete it, I used 3rd party file explorer but still no avail.
    Can someone explain to me what are these files in 'OTHER' and is it possible to clear it?
    OxygenOS version: 5.0.1
    Android version: 8.0.0
    Storage: 64GB
    Anandu p likes this.
  2. RedKnght
  3. NovinDavis
    KitKat Feb 20, 2018
    NovinDavis , Feb 20, 2018 :
    guess all that data which Oneplus stole from users is coming back to your device !!
  4. NovinDavis
    KitKat Feb 20, 2018
    one a serious note .. it is mostly thumbnail which is taken data download es file manager .. then search for thumbnail it should be like a GB or more ... secondly clear cache by going to storage .
  5. PARTHI_SaNjay
    Honeycomb Feb 20, 2018
  6. Ankurrr1
  7. Silviu094
    Gingerbread Feb 20, 2018
  8. apopet26
    Froyo Feb 20, 2018
  9. B1519144856914
  10. I1519146587588
  11. Tummilla
    Froyo Feb 20, 2018
    Tummilla , Feb 20, 2018 :
    even i faced wid d same problem nd I tried all d methods nothing worked.So i tried resetting the phone.Even that didn't work.So i hard reset my phone.Then the storage got back to normal space.
  12. Ash645
    KitKat Feb 20, 2018
    Ash645 , Feb 20, 2018 :
    it's usually logs.
    do this -
    Settings-->Developer Options-->Logs.
    Then press "Delete history log" and uncheck "save log".
    then delete oem_logs folder using file manager, if it's still present
    F_Kuntal_Roy_IQcV likes this.
  13. Uriyah
  14. NIZAMMUHAMMED
    Froyo Feb 20, 2018
  15. PureGenius
    Froyo Feb 20, 2018
    PureGenius , Feb 20, 2018 :
    Its all the data files from the apps you have installed. It doesnt count them to the apps data usage
    idkwhoiam322 and VaibhavBhargava like this.
  16. Seadoh
    Seadoh , Feb 20, 2018 :
    Have you checked that your third party explorer app isn't storing your deleted files in an effective recycle bin? I had the same issue with es file explorer and you have to turn off the autosave deleted files option as well as finding the deleted files folder and emptying it.
  17. Sandwiches
    Honeycomb Feb 21, 2018
  18. sudhirpillai70
    Cupcake Feb 21, 2018
    sudhirpillai70 , Feb 21, 2018 :
    All the messaging apps data in there..it stores all pictures/videos you send out...find those apps like WhatsApp and find the media folder to clear them out..
    idkwhoiam322 likes this.
  19. Venchy
    Eclair Feb 21, 2018
    Venchy , Feb 21, 2018 :
    OEM_LOG Files would be the culprit.
  20. F_Abhijit_Shrikhande_sbx
    Gingerbread Feb 21, 2018
    F_Abhijit_Shrikhande_sbx , Feb 21, 2018 :
    WhatsApp Backup files consume a lot. You will need to deep dive your internal storage using file explorer.
    Also major chunk of others is your Installed Apps.
    See below.
    Screenshot 1 shows Apps = 10.76 GB
    Screenshot 2 doesn't show Apps ; which means 10.76 of 14 GB others is Apps.
