OnePlus 3T USB device not recognised
  1. ursmdnpavan
    Eclair May 15, 2017
    ursmdnpavan , May 15, 2017 :
    Hi,
    My OnePlus 3T is not recognising in my pc. windows 10 64bit OS running creators update.
    i installed OnePlus usb driver will it shows usb not recognized nd asked the usb last you connected either malfunctioned or corrupted.
    few weeks back it use to recognise but now it's not happening.
    meanwhile i checked in my office pc n bro's lappy which runs same windows 10 creators update the and my device is recognising. only issue is with my pc.... all times i connected thru same cable by the way.
    I initially thought it my pc problem so did reset twice complete format all drives but still issue not resolved.
    Its not even charging my mobile when connected to my pc changed ports both front n back but no luck...
  2. vallabh budhkar
    Gingerbread May 15, 2017
    Yash Bhardwaj likes this.
  3. pa5t1s
    User of the Year 2014 May 15, 2017
    pa5t1s , May 15, 2017 :
    Check these posts
    https://forums.oneplus.net/threads/how-to-transfer-data-with-pc.524949/#post-16063374
    https://forums.oneplus.net/threads/how-to-transfer-data-with-pc.524949/#post-16063444
  4. KevinT.
    Froyo May 15, 2017
    KevinT. , May 15, 2017 :
    Happens to me with my other devices. Doing a PC restart often fixes the problem for me...
  5. pa5t1s
    Much true.
    I advise OP to use a nice little tool to delete all obsolete entries in his registry UsbDeView by NirSoft
  6. aajitsaria
    Cupcake May 15, 2017
    aajitsaria , May 15, 2017 :
    You may do a system restore in windows 10 prior to the date it was working fine and it should solve the problem.
