2
OnePlus 3T
  1. killerghost01
    Donut Feb 4, 2017
    killerghost01 , Feb 4, 2017 :
    Hi , i recently bought a OnePlus 3T and i have a question.
    Why does the battery drain so much when the phone is idle?
    F_Avinash_GYLi and Rajesh42 like this.
  2. killerghost01
    Donut Feb 4, 2017
  3. Sandernieuwschepen
    Cupcake Feb 4, 2017
    Best Answer
  4. Shaun Lobo
    Froyo Feb 4, 2017
    Shaun Lobo , Feb 4, 2017 :
    you need to activate developer settings first.Then turn on doze mode...it wont drain so much after u enable it
  5. Rj1988
    Donut Feb 5, 2017
  6. airiartev
    Jelly Bean Feb 5, 2017
    G_Dakshin_Sundar_hivD likes this.
  7. meruraj
    Cupcake Feb 5, 2017
    meruraj , Feb 5, 2017 :
    It does because it has many background app running... You should clear the recent app
  8. Rajesh42
    Cupcake Feb 8, 2017
    Rajesh42 , Feb 8, 2017 :
    no no recent apps
  9. Rajesh42
    Cupcake Feb 8, 2017
    already on the same. battery drains almost 5% everytime it goes into the idle mode
  10. Kiran.a.joseph
    Jelly Bean Feb 8, 2017
    Kiran.a.joseph , Feb 8, 2017 :
    Apps and services will run in the background even though you clear the recent apps list. You can check this in the active/inactive apps list in developer options.
  11. Bobgraton200
    Froyo Feb 8, 2017
  12. Rajesh42
    Cupcake Feb 8, 2017
    right. i just answered about that "recent apps" thing. you're right about the background apps. but 5-6% is normal? for instance, leaving the phone in the night with 40% and in the morning, I see it with 35 or 34% left. is it fine? please tell :)
  13. Kiran.a.joseph
    2 to 3 % seems normal to me.
    Try enabling app auto-launch and aggressive doze mode to see if it helps
    Rajesh42 likes this.
  14. Rajesh42
    Cupcake Feb 8, 2017
    ok. thanks :)
  15. F_Avinash_GYLi
    Cupcake Feb 11, 2017
  16. nareshnas
  17. pedroborgesribeiro
    pedroborgesribeiro , Feb 11, 2017 :
    i think you're right!
  18. ABILASHJOHNYC1
    Donut Feb 17, 2017
