13
OnePlus 5/5t possible lag/stutter fix
  1. KP OnePlue
    Gingerbread Jan 10, 2019
    KP OnePlue , Jan 10, 2019 :
    Like a number of you, I've been experiencing stutter and some lag since updating to Android Pie. I've also noticed that it felt like something was running in the background that contributed towards this. Then I discovered my on my WiFi preferences that Turn on WiFi Automatically and Scanning Always was on. As soon as I switched these off, meaning no automatic scanning or searching for WiFi was on, I noticed I have next to no lag and stutter now.
    So go into Settings, type in WiFi Preferences in the search. Under WiFi Preferences, turn everything off there.
    This fix may not work for everyone, but it's certainly worth trying until a stable update is available.
    I hope this helps.
  2. srinivas9411
    Donut Jan 14, 2019
    srinivas9411 , Jan 14, 2019 :
    Thanks it did help ,but i still see the issue of lagging and phone hanging some times looks like oneplus should address the issue
    WindyCity63 and B1528065145452 like this.
  3. B1528065145452
    Cupcake Jan 14, 2019
    WindyCity63 likes this.
  4. srinivas9411
    Donut Jan 23, 2019
  5. Nerdtality
    Donut Feb 26, 2019
    Nerdtality , Feb 26, 2019 :
    The problem still exists on 9.0.3 firmware OP5T Beta 24.
    Issues with Audio and Video files unless connected to Bluetooth.
    B1514900966419 likes this.
  6. Nerdtality
    Donut Feb 26, 2019
  7. Mr_Cyrox
    KitKat Feb 26, 2019
    borft likes this.
  8. borft
    Jelly Bean Feb 26, 2019
    borft , Feb 26, 2019 :
    there is no such version... that's like saying the bug is in Windows vista 10 or something ;) they are 2 separate builds
    Mr_Cyrox likes this.
  9. Juampii17
    Gingerbread Feb 27, 2019
    Juampii17 , Feb 27, 2019 :
    enable developer options hitting build number many times and then go to system/developer options and disable HW overlays. This removed every single lag in the system. Pretty happy with it, I can confirm that works for me because enabling it for some hours I start to notice lags and then with it no single lag.
  10. Zaphodrocks
    Ice Cream Sandwich Feb 27, 2019
    Zaphodrocks , Feb 27, 2019 :
    Disabling hardware overlay will lead to choppy videos and consume more processing power and battery. It's they for a reason and it has nothing to do with the UI stutter.
  11. Juampii17
    choppy videos while recording? battery works pretty much like my average
  12. Zaphodrocks
    No, usually while rendering views. Some apps will misbehave and won't render properly. There will be a marginal increase in battery consumption as well. It's just a debugging option for developers.
  13. ishaanbahal
    Eclair Feb 27, 2019
    ishaanbahal , Feb 27, 2019 :
    I'm facing this since the last update, I've got 9.0.3. Can't quite figure out what is causing this and don't even know if the bug reports I'd send would include anything about CPU/GPU usage by apps. Just hoping someone found a fix for this because the wifi thing didn't work and can't stop the HW Overlay because a lot of apps start misbehaving, especially video ones, even flutter based apps.
    My friend also has the same Oxygen OS version on 5T but he doesn't seem to face this issue.
    Is there a way to monitor CPU usage per app without root? Apologies if I'm asking the wrong question or this is the wrong place.
  14. sercankd
    Cupcake Mar 10, 2019
    sercankd , Mar 10, 2019 :
    Problem still exists after months, i am on 9.0.4 Stable and its becoming noticeable more each day.
    dareknowak likes this.
  15. Abdul-Sami
    Cupcake Mar 21, 2019
    Abdul-Sami , Mar 21, 2019 :
    Has anyone found a solution for this? I've tried everything in these posts but still have the lag issue. I'm on stable 9.0.4
  16. Sanjayg0912
    Eclair Mar 21, 2019
    Sanjayg0912 , Mar 21, 2019 :
    same. randomly comes and goes.
  17. adeelazmat
    Cupcake Apr 17, 2019
    adeelazmat , Apr 17, 2019 :
    I have got the exact same problem of random lagging of phone till it becomes unusable and then goes away on its own. it gives tv jitter screen while its lagging very hard and the touch is working fine but the system is responding very slowly. this is very annoying.any fix ?
  18. Mr_Cyrox
    KitKat Apr 17, 2019
    Mr_Cyrox , Apr 17, 2019 :
    Yes, there are fixes...
    But not in this thread...
    adeelazmat likes this.
  19. adeelazmat
    Cupcake Apr 18, 2019
    adeelazmat , Apr 18, 2019 :
    Can you guide me to a thread please. I am new here. Thanks
  20. Mr_Cyrox
    KitKat Apr 18, 2019
    Mr_Cyrox , Apr 18, 2019 :
    I noticed you're new...
    This is your second post...
    Just put your phone away for 30-60 seconds (don't use it keep it locked) and it should go away... Or just restart the device...
    Also charge your phone overnight even if the battery is 100% as the phone does optimization at that time I heard so try that too...
