13
OnePlus 5/5t possible lag/stutter fix
  1. justwondering
    Froyo Apr 21, 2019
    justwondering , Apr 21, 2019 :
    so as a temporary fix I found enabling 'Disable HW Overlays' from developer options helps a lot.
    adeelazmat likes this.
  2. Abdul-Sami
    Cupcake May 3, 2019
    Abdul-Sami , May 3, 2019 :
    Just got the 9.0.5 update... And guess what?? The lag is STILL there... Looks like OnePlus are not going to sort this out.. it's been 3 months now... Was looking at getting the OnePlus 7 pro... No more..... Bye OnePlus
  3. Waveform Modifier
    Marshmallow May 3, 2019
    Waveform Modifier , May 3, 2019 :
  4. Abdul-Sami
    Cupcake May 4, 2019
  5. Vikash raju
    Eclair Jul 28, 2019
    Vikash raju , Jul 28, 2019 :
    hey , I was using this for a while but, it keeps going off automatically. and it drains battery. but this is the best solution to the issue.
  6. Juampii17
    Gingerbread Aug 8, 2019
    Juampii17 , Aug 8, 2019 :
    update to oos 9.0.8 lags have been fixed since 9.0.6 more or less. I'm using 9.0.7 with weeb kernel and haven't seen any lag
  7. RDavik
    Cupcake Aug 20, 2019
  8. Mixproof
    Cupcake Sep 2, 2019
    Mixproof , Sep 2, 2019 :
    Hi guys. Guess i found a fix for this lagging issue. It is more than 400 hours alive still no lag. Here come's the solution. Just lock the below 3 applications, by this way they will stay open in the background even if you clear open apps and see the magic. Chrome, WhatsApp, Phone applications must be locked for bacground operating. This works for me. Just tell me your experience if it works for you too.
  9. getaceres
    Donut Sep 2, 2019
    getaceres , Sep 2, 2019 :
    For me it happens randomly since the Pie update. It's quite noticeable while scrolling since it tends to stutter a lot. My fix is to just lock the device and then unlock it with my fingerprint. The stutter is gone magically. Weird.
  10. Mixproof
    Cupcake Sep 2, 2019
    Just 1 difference from your solution. I just do it once. No need to do anything further. For now
